Novice question - How to save the car in this situation?
This ^
OP I learned to drive when i started karting at 9, its a very good way to learn basic race strategy, car control, driving techniques, and learning turn apexes and exiting, very good way to hone your skills see if you can find a track with karts that go up to 50mph, these carts will give you the best learning and practicing opportunity.
When im not on the track, im at the go kart track.
you countered too slowly just remember that the majority of what you do on track is based around vision and feel make sure you are looking way way ahead and your hands will react a lot quicker and don't get set into not moving your hands especially if you find yourself in a slide.
哥们儿你是03-04的base model吗?我觉得主要有两个问题,第一是你在弯中看得不够远,如果在弯中看出弯方向看得够远的话,车身出现slide之后, 如果有不错的autocross的经验的话,大脑会自主去然双手控制住方向。我个人认为多去跑跑autocross可以大大提高 car control的能力。第二点,你需要升级LSD,如果这是03-04的base model的话,它是open diff。低速情况下漂移或者spin的时候,内侧车轮的速度会得不到良好的控制,说白了就是会过快,造成失控。高速漂移时也更 是很难去控制。即使在更高配置的车上有VLSD,但原厂VLSD的性能也是远远不够的。升级LSD是个非常必要的选 择。
个人意见仅供参考
个人意见仅供参考
Subarism
East Canada
Sep 23, 2015 06:09 PM
