Track Car Body Work
Old Oct 15, 2013 | 03:26 PM
N80's Avatar
N80
Default Track Car Body Work
Let's say you had a Z with a lot of body damage but otherwise in good shape and you wanted to make it into a track car. It would need a rear bumper, rear hatch, driver door, right rear quarter panel and left lower fascia.
Are there enough Z body parts in salvage yards to put things back together on your own on the cheap? I'm not talking about a show room restoration, just good enough for the track with a DIY paint job?
Old Oct 15, 2013 | 03:40 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Yes it would be easy
Old Oct 15, 2013 | 03:59 PM
03threefiftyz's Avatar
03threefiftyz
The rear quarter panels are expensive to get put in....other than that, not much of a problem.
Old Oct 15, 2013 | 06:21 PM
N80's Avatar
N80
Man, looking at salvage yards online 350Z body parts are expensive! Door assembly in "good" (not "very good") condition for $750. Rear quarter panels $650. I can't imagine how much the rear hatch would cost.
I sure hope aftermarket panels are less.
Old Oct 15, 2013 | 06:26 PM
Neeko94's Avatar
Neeko94
Id rather buy and abused one for 6K and go from there.
Id assume your replacing all the performance components for the track anyways right?
why waste your money on replacing body panels that have no performance gains?
Old Oct 15, 2013 | 06:28 PM
N80's Avatar
N80
I did not realize the rear quarter panel included the triangle window and all that. Does it have to be welded in?
Old Oct 15, 2013 | 06:29 PM
N80's Avatar
N80
I already own the car.
Old Oct 15, 2013 | 06:49 PM
03threefiftyz
Yes, the rear quarter has to be cut out and rewelded back in....
....it is usually 3-4k easy to get one replaced after an accident, or so I've heard.
Old Oct 15, 2013 | 07:10 PM
samsniss350z's Avatar
samsniss350z
Parts are at a premium because the 350Z is a sports car, perhaps another alternative if you have the space is to buy a shell that has front end damage and purge all that you need in one go?
Old Oct 15, 2013 | 07:13 PM
Neeko94's Avatar
Neeko94
just fiberglass the ISH out of that thing.
save your money.
and who needs a hatch?
Make it a convertible and have that weight reduction!!!
Old Oct 15, 2013 | 07:47 PM
J 0 K 3 R's Avatar
J 0 K 3 R
for the quarter panels do either a huge over fender and riveted on. Or bang it out with a body hammer and dolley, and bondo the crap out of it. its also far less intrusive to the car than cutting the spotwelds out and mig welding a new fender on. its pretty much a hack job even if u pay 5k for it.
Old Oct 15, 2013 | 09:31 PM
terrasmak's Avatar
Aftermarket and used parts. Rear 1/4 panel is tricky, for a dedicated track car I would find someone to make molds and go fiberglass will possible wide body rear. Do some cutting and make the rears simple to change out.
Old Oct 16, 2013 | 02:08 AM
mhoward1's Avatar
mhoward1
If you are thinking about taking it W2W spec racing then most likely OEM is the only real choice. As said It may be worth finding a shell with a blown engine and move over the parts.
A lot is going to depend on where you plan to be with the car in the next year or so.
Old Oct 16, 2013 | 06:42 AM
N80's Avatar
N80
The rear quarter panel damage is the least of all the body damage and I may see if the body shop can hammer it out/bondo and then replace the bumper, door and hatch. I bet the hatch is going to be pricey.
Anyway, if they can get it looking decent without breaking the bank I'll keep it as my DD and find something a little cheaper to crash at the track.
If it is going to be too expensive to get it back to normal I may just get them to do the best they can on the rear quarter without replacing it and then park it for a while until I can do the rest myself. I've got a buddy who can do a good enough DIY shade tree paint job for a track car.
Old Oct 16, 2013 | 11:00 AM
Voboy's Avatar
Voboy
you could do that.... or miata..cheapest option for racing
Old Oct 16, 2013 | 11:05 AM
DmanG281's Avatar
DmanG281
In the same boat and I have had good luck with ebay and the marketplace here. I got 2 front fenders the same color as my car for $175 shipped on ebay. So deals are out there if you are patient.
Old Oct 16, 2013 | 11:45 AM
N80's Avatar
N80
I like the idea of a Miata but I'm 6'4" and barely fit in my Z so I'm not sure if I'd pass the "broomstick" test with the roll bar. A friend of mine has one so I can check it out easy enough.
N80's Avatar
N80
Thanks. I will start looking.
Old Oct 16, 2013 | 12:38 PM
mhoward1's Avatar
mhoward1
Like I said, I would think about where I want to be in a year or more. If it's racing, find a class that appeals to you, and one that has a future. If it's spec Z, then fix the Z. other great classes would be spec Miata or Spec E30. Cheap fun, great racing. In the Southeast you could get a Thunder Roadster cheaper than fixing the Z and be out there racing with 20 other guys. With the possible changes in STx it could be come very popular.
If it's just doing track days or looking at Time trails, then spendign that money on a C5 vette is hard to beat. they are great track cars out of the box, and they are competitive in TT as well.
Old Oct 16, 2013 | 01:33 PM
sig11's Avatar
sig11
You can fit! A shop here (V2 Motorsports) built a spec miata for a fella who is 6'6".
