Gutting rear/half - better, worse or no difference ?
Old Dec 4, 2021 | 07:22 AM
KaizerWilhelm's Avatar
KaizerWilhelm
Originally Posted by iideadeyeii
I think you are overestimating the weight savings. I've gutted many cars. The sheet metal is almost nothing, then adding the cage I'd assume you'd add weight overall. If someone who has done this has any weight numbers that would be great
Yes, I will be adding weight with the cage going in, no doubt. But better to add cage - sheetmetal, vs cage + sheetmetal. very curious to see what mine will weigh after all is said and done and if it'll be under 3300lb like @Dr Hoon
Old Dec 4, 2021 | 09:57 AM
bealljk's Avatar
bealljk
One large swap that can be added (without a safety compromise) is going cf/fiberglass doors. I picked up a set and between both doors you can deduct 50 to 60lbs off the car.
Dr. Hoon Edit (from below) - meaning / clarifying: Yes, if you have the right cage with side protection you offset a portion of the added cage weight by going cf/fg doors.
Old Dec 4, 2021 | 03:18 PM
Dr Hoon's Avatar
Dr Hoon
5 Year Member
I'll play health and safety here, you don't want to install lightweight doors unless you have full cage with door bars. I've seen some bad track accidents where the driver survived only because of door protection, don't be a statistic.
Old Dec 6, 2021 | 01:21 AM
RobPhoboS's Avatar
RobPhoboS
Yep, I wont' be full cage now but if I was going to do that, for sure I'd also look at the doors as they are HEAVY AF!
Sounds like the wife is going to buy me a Milwaukee drill (M18FPD2-0) for Christmas, that'll certainly help
Old Dec 13, 2021 | 12:55 PM
Blurvision's Avatar
Blurvision
A quality roll will be great for track safety. Nothing good for street use. Do it
Old Dec 14, 2021 | 12:13 AM
RobPhoboS's Avatar
RobPhoboS
Started pulling bits and pieces out now
I found some rust on the inside/rear strut tower, bit odd but the nice chap doing my cage said he can sort it out properly. So I shall keep looking over the car to find any other problematic areas, bit strange as the car is garaged and not really used over winter.
Old Dec 17, 2021 | 03:14 AM
KaizerWilhelm
Picked up my Z yesterday from 425 Motorsports after getting the cage and false floor installed. As you can see they created a new, better looking/stronger strut tower brace for the rear.
Old Dec 19, 2021 | 11:06 AM
Dr Hoon's Avatar
Dr Hoon
5 Year Member
If you want to have passengers with heads you'll want to get a lower seat mount. I'm 5'11" and I've had students with race seat setups like this and I was not able to fit in their car with the helmet on, had to find a shorter substitute instructor for them. Just FYI, there are better solutions out there.
Old Dec 19, 2021 | 12:52 PM
KaizerWilhelm
What do you recommend? I've had 6'+ instructors sit in there with no issue, but always open to suggestions. I've currently got Planted seat brackets and seats on the lowest setting.
Old Dec 19, 2021 | 05:52 PM
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Instead of flat plate mounts you'd need either side mount brackets or drop mounts that allow the seat to be mounted below the height of the mount points. Here's an example of such bracket (the one in the back is pass side drop mount)
Here's a pic of the 350z side mounts
Old Dec 20, 2021 | 12:50 AM
RobPhoboS's Avatar
RobPhoboS
It's much worse if your car is RHD !
The guy that is doing the work on my car did my seat a few years ago:
Got to here so far, more over the Christmas break & new drill
Found some nice rust to cut out and deal with too :-/
Old Dec 20, 2021 | 04:40 AM
Dr Hoon's Avatar
Dr Hoon
5 Year Member
I can't really tell if the RHD right side floor is as f'd up as LHD floor based on these pics, but yeah the other option is to mod the floor itself to make room for the seat mounts. Looks like you're well on your way Rob
Bdizz777
Dec 21, 2013 04:04 PM
OldManZ350
Apr 7, 2008 01:19 PM
HXS
May 15, 2006 07:53 AM
SKiDaZZLe
Jun 1, 2002 07:11 PM
