Craftsquare mirror install...
Old Sep 10, 2007 | 12:54 PM
MaRbLe's Avatar
MaRbLe
Default Craftsquare mirror install...
Step 1:
Pop center of handle out and remove screw.
Step 2:
Remove arm rest cover and bolt
Step 3:
Remove bolt in handle.
Step 4:
Carefully pop of the door panel snaps.
Step 5:
Unbolt original mirror and disconnect the wire harness.
Step 6:
Bolt on Craftsquare mirror via the original mirror holes. Its helpful to have another person to help with adjustments.... One person to hold align the mirror and hold in place while another tightens the bolts. From there adjust your mirror view and tighen the adjustment bolts down.
Old Sep 10, 2007 | 03:06 PM
doodeitstom's Avatar
doodeitstom
nice mods, but no drop?
Old Sep 10, 2007 | 03:22 PM
MaRbLe's Avatar
MaRbLe
Have Cusco Zero-2's all around, cant drop more or I cant get into the driveway LOL
Old Sep 10, 2007 | 06:41 PM
918 Z's Avatar
918 Z
very nice! how much were they?
Old Sep 10, 2007 | 07:11 PM
MaRbLe's Avatar
MaRbLe
I got them from z1auto, here is a link to their site with all the Craftsquare syles. I ended up getting the N1 type...
http://www.z1auto.com/
Old Apr 14, 2008 | 07:43 PM
mdracer76's Avatar
mdracer76
bump.. thanks for the great instructions. .. I may try to get mine on before HIN.
Old Apr 16, 2008 | 10:31 AM
DRFTER_Z's Avatar
DRFTER_Z
my oem mirror is loose at the base...... can you be a little more detailed on how to take off the small plastic where the oem tweeter is so i can access the bolts of the mirror? I hope they are just loose..... I would rather do it my self rather than have the dealer do it and take a week
Old Apr 24, 2008 | 09:23 AM
DRFTER_Z's Avatar
DRFTER_Z
bump!
Old Apr 24, 2008 | 12:31 PM
Chebosto's Avatar
Chebosto
the oem tweeter plastic just lifts up and unclips from the aluminum plating. the way they designed the plastic door covers is that you'll need to remove the door panel before you can get to the tweeter cover.
just besure you dont knock off the foam padding that's stuck to the inner panel of the plastic door panel. if if falls off you'll need to use foam glue to stick it back to the plastic-
tip for plastic door cover.. lift UP there are clips in the metal door, and the plastic has 'hoops' to engage the clips. if you lift the cover up. you will reduce the risk of breaking or popping off the clips-
Old Apr 24, 2008 | 01:54 PM
DRFTER_Z's Avatar
DRFTER_Z
Thank you so much Cheston! finally someone helped
Old May 9, 2008 | 09:40 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Nice! Gonna need this in a couple months.
Old May 12, 2008 | 11:36 AM
ZKansasZ's Avatar
ZKansasZ
they look great!
But are they functional like oem one? I mean can we adjust them with oem switches?
Old May 12, 2008 | 11:49 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by ZKansasZ
they look great!
No. You lose the power function. But than how often do you truely adjust your mirrors?
Old May 12, 2008 | 06:58 PM
OH6 G35's Avatar
OH6 G35
Damn...that looks great!
Old May 13, 2008 | 04:48 AM
imonlykidden's Avatar
imonlykidden
Nice, i did mine as well.....i had them painted the same color as the car. (black) the base i mean, not CF. looks good either way.
Good job.
Old May 13, 2008 | 04:50 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Good job.
Mind PMing a pic of your's installed? Thanks!
-Robert
Old May 13, 2008 | 05:13 AM
imonlykidden
pm sent.
Old Aug 11, 2008 | 01:57 PM
Swifty's Avatar
Swifty
Thanks alot for the "write up" it helped me out alot last night when i was installing mine!
Old Oct 15, 2008 | 05:24 PM
yogipower's Avatar
yogipower
greeeeat write up.... i'm going to do mine too soon as i get my mirror =) can't wait!
Old Oct 15, 2008 | 07:55 PM
lgear080's Avatar
lgear080
Step 7 - sell craftsquare mirrors to lgear080
oh yeah... great write-up. been meaning to score these for a while.
