DIY: TS Rear Diffuser Installation Instructions
Old Aug 8, 2011 | 07:50 PM
  #101
slow7's Avatar
slow7
thanks man very helpfull
Old Aug 14, 2011 | 06:36 PM
  #102
dreamspeed's Avatar
dreamspeed
nice looking piece, i love parts that add on to the factory parts instead of completely replacing them.
Old Apr 22, 2012 | 08:22 PM
  #103
350z___'s Avatar
350z___
anyone got pics of this installed w/ hks rep exhaust?
mines is coming this week and want to get it installed.
also if anyone know where to exactly cut the diffuser so it fits perfect w/ hks rep exhaust
Old May 3, 2012 | 09:46 AM
  #104
350zbehold's Avatar
350zbehold
the hks need alot of cutting but it fit....therefore more cutting to the diffuser mean less stabilize the diffuser will be here is mine
Old May 3, 2012 | 01:43 PM
  #105
PikesPeakZ's Avatar
PikesPeakZ
[QUOTE=350zbehold;9722995]the hks need alot of cutting but it fit....therefore more cutting to the diffuser mean less stabilize the diffuser will be here is mine
Incorrect barely any cutting involved at all. I am running this diffuser with my HKS Hi Power Ti true dual.
Pics of where to cut are below:
You can see you only need to notch the lip on the back side for the canisters.
Test fit shots:
The previous post where they modified the diffuser for the HKS hacked the **** out of the diffuser un-necessarily.
Old May 3, 2012 | 03:24 PM
  #106
350zbehold's Avatar
350zbehold
well maybe you have the real hks ...many and i mean many peeps from here running x02 and other replicas in therefore are tiny different...but when u cut them did you sand the cut down to prevent spider crack ??? cause i cut it with electric jigsaw so it pretty clean cut
Old May 3, 2012 | 03:29 PM
  #107
PikesPeakZ's Avatar
PikesPeakZ
Yes I made sure they smoothed and sealed the cuts. That was just test fitting. I do have a legit HKS which may make the difference. Your car looks great BTW!
Old May 4, 2012 | 01:38 PM
  #108
350zbehold's Avatar
350zbehold
the main part is did any of you guys drill a hole near the end of the diffuser for water to exit when you wash the car...because when i wash my car water tend to stay inside and within the bumper..everytime i have to blow the water out with my grass blower..it pretty fun ... but kinda pain in the ***
Old Aug 9, 2012 | 08:36 AM
  #109
sry110's Avatar
sry110
First, thanks to Cheston for writing this DIY.
Now to expose my own mental density: I've read through this 4 times and I still do not understand how to mount the rear center portion to the bumper. I see the heads of two (2) screws, presumably the long machine screws included with the installation hardware kit. But what I cannot fathom is how I will be able to reach inside the rear bumper, with the diffuser and muffler tips in place, to hold a nut into which those screws could thread.
So what I am thinking is this:
1) Modify the rear "U" bracket to accept "Screw clips" over the two holes on one flange. (Picture of screw clip below....i.e. the same thing that is used to secure the stock rear mud guard in place). The screw clips will be on the "outer" flange of the U bracket, where the diffuser will mount to it.
2) Use short screws and nuts to mount the rear "U" bracket to the bumper.
3) Use sheet metal screws to hold the diffuser to the "U" bracket, with the screw grabbing into the screw clip. The drawback here is that the heads of sheet metal screws tend to look not-as-nice as the heads of machine screws, but I will most likely paint the screw heads black in any case.
My thought it that this makes removal/re-installation of the diffuser much, much easier, should I ever need to sell it, or perform maintenance on the exhaust system, etc.
Any drawbacks that anyone can see to this approach, before I go effing up my bumper?
I think the same approach would work for the holes in the "Z" shaped brackets that hold the diffuser to the bottom of the bumper on each side.
Side note: I am also thinking of taking a large piece of cardboard and cutting a rectangular hole in the middle that is slightly larger than the flange of the "U" bracket, and using the cardboard as a template to spray a healthy patch of black plasti-dip onto the bumper, on top of which the "U" bracket will mount. This way, if/when I eventually remove the diffuser, I should be left with just two holes in the bumper as opposed to two holes and a rectangular scuff mark.
Old Aug 9, 2012 | 02:18 PM
  #110
Chebosto's Avatar
Chebosto
It's actually FOUR bolts total. two bolts that attach the U bracket to the rear bumper., then two bolts to attach the diffuser to the U bracket..
it is not ONE long bolt that goes through both the diffuser, U bracket, and rear bumper. (which i have seen done, that is not the correct way)
once the side Z brackets are in place, you can get the alignment of the center U bracket. i noticed that you said yours wasn't PREDRILLED, however on the authentic Top Secret diffuser, it is, i would suggest you playing around with placement of the U bracket on the inside of the diffuser and test mounting it to the back of the bumper to see where you want to put the bracket. some exhausts allow you to reach up behind the OE bumper quite high (almost to the bumper crash beam support, and that is where i was able to reach with the lock nuts to fasten the U bracket to the rear bumper.
i have seen variations of the U bracket where nutserts were used on the side receiving the diffuser. after the U bracket is hard mounted to the rear bumper, simply attach the diffuser and put two bolts in and they will tighten via the nutserts. really simple.
+1 on the plastidip, you can also use painter's tape as you will not be able to see it when the diffuser is attached.
Old Aug 9, 2012 | 02:35 PM
  #111
sry110's Avatar
sry110
^ thanks for the additional insight. I should have clarified, mine (Shine replica) is not predrilled, but has indentations where all the holes are to be drilled. So all I had to do was carefully drill them out.
I guess the nutserts have to be positioned in the bracket such that the little flange is on the opposite side of the bracket from the diffuser, so that the as the screw tightens the nutsert pulls back against the bracket......but what keeps the nutsert from rotating with the screw?
Old Aug 9, 2012 | 05:16 PM
  #112
sry110's Avatar
sry110
Welp I don't have enough patience to order nutserts and wait for them to be delivered, so I went on my initial idea utilizing the screw clips from the stock rear mudguards. I super-glued the flat part of the clip to the front of the bracket (which adhered surprisingly well!), and the back part on the inside of the bracket just floats there but clamps in against the bracket when the screw is tightened:
I'll reuse a couple of the sheet metal screws from the stock mud guards, with a fresh coat of gloss black Rustoleum on them:
Sorry for crappy iphone photos
Old Aug 11, 2012 | 10:38 AM
  #113
Chebosto's Avatar
Chebosto
ack! dont use sheet metal screws, you can probably find the correct pitch on a stainless steel button head allen bolt at homedepot / lowes / osh..
it'll looks wayyyyy cleaner than a phillips machine screw..
as for the aluminum bracket.. hmm.. was this a Shine Replica?
Old Aug 11, 2012 | 02:05 PM
  #114
sry110's Avatar
sry110
Haha yup I agree. I was at the hardware store the other day and found a couple that might work, but when I got there I realized I had forgotten to bring the OEM sheet metal screw so I couldn't match the thread.
And yes, this is a Shine replica. I'm in the process of measuring 3 times before I drill, but in the process I did have to do some Dremel trimming/sanding where the diffuser wraps into the exhaust tip cutouts from the outsides. Up at the top "corner', the inner part of the curve stuck up too high and would jab into the bumper when I tried to move it into position. That took some extra time so I plan to finally get the thing mounted tomorrow. I also had to notch out the front flange on one side to fit around the rear pipe of my Invidia Gemini exhaust.
NOTE: The "Z" brackets that come with the shine kit are also silver aluminum. So I'm going to have additional time into it painting those brackets black prior to final installation.
Another side note, the carbon weave on the Shine piece is sub-par in my opinion. Maybe on-par for a replica, but I've had other less-expensive carbon fiber replica pieces with better weaves than this. Also plenty of surface imperfections, many of which are visible. Probably fine from 5 feet away, but painful when you spend all afternoon up close and personal with it.
Old Aug 12, 2012 | 05:11 PM
  #115
Andrei's Avatar
Andrei
If you look at an 07-08 Nismo 350z, the rear bumper has a big rectangular hole in it to let air escape across the entire length, and the bumper does not extended all the way to the bottom like a regular bumper because the regular canister muffler is not there to prevent air from being trapped inside the bumper.
So if you remove the OEM canister muffler and use tips only and use this diffuser that doesn't have enough of a lip under the car to prevent air from being trapped, it just creates drag. The only way to fix it would be to extend the lip much higher up to the trunk floor to prevent any air from being trapped in the rear bumper.
So in my opinion, it's not functional at all.
Old Aug 12, 2012 | 06:11 PM
  #116
sry110's Avatar
sry110
Yeah I bought one because it looks badass.
Old Aug 13, 2012 | 08:49 AM
  #117
Chebosto's Avatar
Chebosto
Originally Posted by Andrei
If you look at an 07-08 Nismo 350z, the rear bumper has a big rectangular hole in the rear bumper to let air escape across the entire length, and the bumper does not extended all the way to the bottom like a regular bumper because the regular canister muffler is not there to prevent air from being trapped inside the bumper.
this was never intended to be used on the Nismo rear bumper. only the non-nismo shaped versions. there are other ways to prevent air entrapment on a Nismo rear bumper if you switch to canisters, you are correct that you have to extend the floor of the diffuser, generally anywhere from axle back.. the vent holes in the nismo rear already aleviate air trapped underneath the car, and main purpse was to alieveate rear wheel drag
Old Aug 13, 2012 | 09:13 AM
  #118
sry110's Avatar
sry110
Re: black painted sheet metal screws, it actually looks alright to me once everything is mounted up. At least it looks good from ~5 feet away, which is as close to my car as I want anyone besides me:
Old Oct 23, 2012 | 01:53 PM
  #119
TS 350Z's Avatar
TS 350Z
what size the drill bits to do the holes??
Old Nov 8, 2012 | 02:11 PM
  #120
SharX59's Avatar
SharX59
I'm wondering, would the shine replica clear a single exhaust set up? I know this wouldn't clear the agency power, but im talking about the greddy single ti-c. I've been at a stalemate for months now with buying an exhaust because I dont want to get a single and to do the bumper tuck and then find out that it would have fit fine with the shine ts diffuser. Anyone have any knowledge to share?
