DIY How to on Relocating your Cruise Control.
Old Jun 26, 2008 | 10:40 PM
got556's Avatar
got556
Wow...always wondered about this.
Thanks for the how to / info!
Old Jul 17, 2008 | 08:19 PM
350ZMPH's Avatar
350ZMPH
Thanks a lot for this info....
Old Feb 24, 2010 | 12:35 PM
04.350z's Avatar
04.350z
Originally Posted by nosurf2day
Step 6. There are 2 screws that hold the turn signal on to the left and right of the center dial, remove them.
Step7. Unbolt the gauge cluster to be able to move it out of the way.
Step 8. There are some screw underneath the center column that holds the whole cluster in unscrew them.
Step 9. Remove the cluster (turn signal, wipers, and the center dial), you will have to remove 4 harnesses behind it, to do this.
I know this is a really old thread but, I did mine the other day and these steps were very unnecessary.
I removed the lower steering Column Shroud and the Grey and Yellow clips were literally right there on the bottom.
I am also going to be putting the Cruise Control Module in the Ashtray in the center Console.
Will Post pics of the Clips as soon as I get around to Splicing the CC back in
Old Feb 24, 2010 | 03:12 PM
nosurf2day's Avatar
nosurf2day
I appreciate you letting people know, with the new hubs you dont need to go through this whole process. I had to because I had to remove the center portion so that I could put my hub in.
Old Feb 25, 2010 | 08:39 PM
04.350z's Avatar
04.350z
Just figured I would update the thread for some people so they didnt do extra work
Old Feb 25, 2010 | 08:43 PM
nosurf2day's Avatar
nosurf2day
no worries, i apprecaite it, i should have one that, i ended up doing all that extra work only to find out the hub went over everything unlike mine. I was pissed.
Glad you figured it out.
Old Mar 26, 2010 | 08:54 PM
nathanwl2004's Avatar
nathanwl2004
Its really easy, the hard part is figuring out where you want it and how to mount it.
in the head liner like jet
Old Mar 26, 2010 | 09:43 PM
nosurf2day's Avatar
nosurf2day
pics of it in the head liner would be sweet.
Old Apr 1, 2010 | 11:17 AM
KingBaby's Avatar
KingBaby
Hardest Setting
crazy idea....
just might want that done....or in the interior a-pillar...
surf when I get my car back you don't mind experimenting with an 07...
Old Apr 1, 2010 | 03:33 PM
nosurf2day's Avatar
nosurf2day
Originally Posted by KingBaby
crazy idea....
Not at all, its really easy I would be glad to help out.
Old Jul 30, 2010 | 12:22 AM
huy350z's Avatar
huy350z
hi, my horn and cruise control dont work, u think the wires just might come lose? bc sometime it work when i turn the steering wheel sometime it doesnt please let me know
Old Jul 30, 2010 | 09:05 AM
nosurf2day's Avatar
nosurf2day
Yes I believe that is the issue. Take it back apart and check your connections. I would recommend soldering your wires together to prevent this.
Old Jan 25, 2011 | 06:36 PM
bmccann101's Avatar
bmccann101
nice, ill have to do this now too.
Old Apr 6, 2011 | 07:44 AM
specialist's Avatar
specialist
Can you please post pic up again?\
Old May 2, 2011 | 08:17 PM
Rckstrgrl21's Avatar
Rckstrgrl21
The Pics seam to have been deleted or moved. ;-/ probably due to the age of the post?
Old May 9, 2011 | 06:41 PM
nosurf2day's Avatar
nosurf2day
Old May 11, 2011 | 10:59 AM
bmccann101's Avatar
bmccann101
i took my cruise plastic off the steering wheel and had it cut stright up and down ( cut off the curve around the airbag etc).
I will be screwing that directly into the coin pocket ashtray thing in front of the shifter.
Clears when flipped closed. Looks clean.
I cannot WAIT to get back the use of my horn.. revvs w test pipes are my only alert in traffic as of now.. so lame.
Should be a pretty simple deal.
Pics to follow when i get off my duff and finish it.
Old Jul 26, 2011 | 10:24 AM
  #38
XsMobe's Avatar
XsMobe
bump
Old Jul 26, 2011 | 10:35 AM
  #39
350zJDMnismo27's Avatar
350zJDMnismo27
I sold my steering wheel along with my cruise control buttons. So now with my aftermarket wheel I always receive a cel. Is there any way to install a resister so that the system thinks the buttons are there, or can I use any cruise control buttons
Old Jul 26, 2011 | 01:07 PM
  #40
Kwame's Avatar
Kwame
How many resistors did you install when you installed your aftermarket wheel? You should have installed two. I believe both are for the airbag because it is a dual stage airbag. The lack of steering wheel controls would not cause a CEL.
