DIY: Painting your stock rims
Old Jun 14, 2009 | 10:36 PM
  #41
ThundrA's Avatar
ThundrA
Originally Posted by Hexxus
That's what results from not doing it the right way. If you take your time and use a good primer to bond it to the metal like the self-etching, you more than likely will not have that problem. All the factory rims I've seen on here and on the street that are chipping and peeling usually reveal that the owner just spray painted them without sanding them down, prepping, or primering them since you can see the factory silver where it chips off. If you sand them down correctly, there is a layer of black primer underneath the factory silver coat, and that's where you want to sand it down to to get the best result and bonding of the metal and primer/paint.
How deep do you actually have to sand it? Until the factory silver disappears and the black primer shows up? I used a 320 grit sandpaper and the the black primer you were talking about only comes up at the edge corner.
I'll post some pictures soon.
Old Jun 17, 2009 | 08:21 AM
  #42
Hexxus's Avatar
Hexxus
You don't have to go down to the black primer in the middle parts of the rim. As long as you get it roughed up, it'll be fine. You'll sand your arm off trying to reach it in the middle.
I use a Bondo block to help make things easier;
http://www.3m.com/US/auto_marine_aer...ml?itemNbr=851
Old Jun 21, 2009 | 11:21 PM
  #43
2004Black350z's Avatar
2004Black350z
Exhaust Whore
eyeSee how is the rims holding up now? Anything u wished u did diff
Old Jun 25, 2009 | 11:38 PM
  #44
domsaywha's Avatar
domsaywha
what heee said. andd is the paint cracking yet?
Old Jul 22, 2009 | 10:00 AM
  #45
350ZzzVrrooomm's Avatar
350ZzzVrrooomm
^^^^ same question as above
I've used the http://bmwtips.com/tipsntricks/wheel...uff-repair.htm to repair the curb rashes on the edges, but I unfortunately bought a different color duplicolor paint. Guy at autozone says its alloy. Anyways, now that sections of the wheel is in a different color, does anyone know the closest match to alloy rims on the 06+ Zs?
Old Jul 22, 2009 | 01:33 PM
  #46
Guahan's Avatar
Guahan
your the new over spray king. i kidd nice color.
Old Aug 13, 2009 | 04:47 PM
  #47
spartan350z's Avatar
spartan350z
The rims look good on both cars, i have an 03 350z thats black, i kind did the same thing but i used a flattening agent on mine and they turned out great, im in greece right now on vacation, and will be back on the 20th of august to post my photos.
Old Aug 15, 2009 | 05:44 AM
  #48
CsabaH's Avatar
CsabaH
Ok it took me some time due to weather(ie high humidity) but they are finally done and mounted. I took some in progress pics as well. It's not an easy job and you have to have some patience but they came out very well. I used the same method as what was described in the above post as well as the video I posted. The paint held up with the tire mounting so I'm happy with that. You would have to look very hard to be able to tell that they were not painted from the factory. I'm more than happy w/ this DIY and I give credit to the orignal poster for putting this thread: https://my350z.com/forum/wheels-and-...storation.html . It gave me the incentive and research to get this job done. I was tempted to stick w/ the gunmetal color but I decided to go for the more factory look. The first wheel I sanded down to just the black primer. The rest of the wheels I did with a mouse sander and got it down to the bare aluminum. I used Rustoleum products because that's all Autozone carried. I used the Rustoleum Self Etching Primer, Filler Primer, Charcoal, Silver and Clear. It takes some time and prep work but it's worth it in the end. The hardest part was actually repairing the one wheel. Working w/ bondo is not fun but it worked. Anyways here's my pics.
Old Aug 19, 2009 | 11:08 AM
  #49
TTwinTTurbo's Avatar
TTwinTTurbo
Sanding is not necessary. I didn't and the paint adhered fine.
Old Sep 1, 2009 | 10:27 AM
  #50
Hexxus's Avatar
Hexxus
How long ago was it that you've done this? I can almost guarantee it's not going to hold.
Old Sep 10, 2009 | 08:35 AM
  #51
bcampbe7's Avatar
bcampbe7
Agreed, if you don't sand you are asking for peeling down the road.
Will I need to rebalance after using the bondo/filler? Just got new tires yesterday which were balanced with the curbed/rashed area.
I doubt it since such a small amount is used, but wasn't sure how much weight in one spot will throw off the balance.
Old Sep 10, 2009 | 12:10 PM
  #52
Hexxus's Avatar
Hexxus
Shouldn't need balanced, but, it wouldn't hurt to have it done anyway.
Old Sep 11, 2009 | 06:13 AM
  #53
adamtaylorpcb's Avatar
adamtaylorpcb
your talking about a couple grams at most
Old Oct 30, 2009 | 01:26 PM
  #54
NateZ08's Avatar
NateZ08
painting your rims....are you kidding me. should i mail your stick on hood vents as well?
Old Oct 31, 2009 | 07:00 AM
  #55
adamtaylorpcb
if you have not noticed, we are in a recession
i know i don't **** rainbows and gold bars so this is a viable solution
Old Oct 31, 2009 | 09:44 AM
  #56
ZKansasZ's Avatar
ZKansasZ
I'd take it if you can mail it to me, please!
Old Jan 25, 2010 | 07:49 PM
  #57
NateZ08's Avatar
NateZ08
then modding your car should be the last thing on your mind if you're that strapped for cash.
Old Jan 26, 2010 | 07:42 AM
  #58
adamtaylorpcb
no, just spending $4k on a set of rims is not as economically sound as a $10 rattle can job fo
Old Jan 27, 2010 | 12:28 PM
  #59
Highway Riding's Avatar
Highway Riding
Right on... and especially if you have some skills. Is this for me? NO but i have some curb rash on my 35th's that could use cleaning up and this thread delivers..
Old Feb 25, 2010 | 04:00 PM
  #60
chrisj485's Avatar
chrisj485
I just finished painting my '07 wheels and they all came out great except for 1 wheel. The clear coat almost looks dusty if you can get what I'm trying to say...should I try to wet sand it or is it maybe that I perhaps didn't apply enough clear coat to the "dusty" areas?
