DIY: Painting your stock rims
Old May 6, 2010 | 08:02 PM
  #61
Mike@Blackline's Avatar
Mike@Blackline
after your 320 sanding you dont do a finer grit? curious if your wheels look really grainy after paint because of this?
Old Jul 19, 2010 | 09:37 AM
  #62
j3dz's Avatar
j3dz
I had a few hours to kill this past weekend. restored my extra rim, spent $28.57 on supplies.
1. clean rim
2. scuff rim (60 grit sand paper)
3. bondo the curb rashes and other blemishes
4. sand bondo (60 grit)
5. sand before primer (80-100 grit)
6. primer (2 coats)
7. sand the primer (1000 grit)
8. apply paint (3 coats)
9. wet sand paint (1500 grit)
10. apply clear coat
11. wet sand clear coat (2000 grit)
now time to see if this will stay
Attached Thumbnails DIY: Painting your stock rims-rimrestoration.jpg
Old Aug 7, 2010 | 11:06 AM
  #63
philmynutz's Avatar
philmynutz
i have those fugly chrome stockers, do you think i can do this? also with what number grit and additional details i might need such as sanding down the chrome to what extent.
Old Aug 7, 2010 | 04:24 PM
  #64
philmynutz's Avatar
philmynutz
no thoughts..?
Old Aug 7, 2010 | 04:34 PM
  #65
c0ld29's Avatar
c0ld29
I believe the steps are all the same even with chrome, just make sure its scuffed up enough to get a good adhesion
Old Aug 8, 2010 | 07:21 AM
  #66
Armed Ferret's Avatar
Armed Ferret
Originally Posted by NateZ08
painting your rims....are you kidding me. should i mail your stick on hood vents as well?
meh. i plan on keeping my stock '06 wheels for track use, so i'll likely rattle-can them something goofy like olive drab or camo or what have you.
easy to change up color, and when they get nicks/etc. it's an easy repair job....and yes, track wheels WILL get nicks and such.
Old Apr 22, 2011 | 07:05 PM
  #67
TreFITTY's Avatar
TreFITTY
Just wondering if you guys painted the inner part of the rim as well? Or just kept it stock? Doing it soon, black, so just getting prepared
Old Apr 26, 2011 | 10:02 PM
  #68
Rckstrgrl21's Avatar
Rckstrgrl21
I am also wondering about visible sanding marks. Im thinking the primer smoothes it out, true?
Old May 5, 2011 | 10:03 PM
  #69
Wipe_Drive's Avatar
Wipe_Drive
^ as long as you arent leaving canyons in the wheel
Old Apr 1, 2013 | 12:02 PM
  #70
CsabaH's Avatar
CsabaH
Just thought I'd update this thread. I did this back in 2009 and have since put approximately 6,000 miles on the car since this mod. The paint has stayed on with no problems w/ chipping or peeling. Again, I don't drive a whole lot and I don't drive in the winter but this was a very simple mod and I'd tell anyone else to do the same if they wanted to fix up their wheels.
Old Apr 1, 2013 | 12:40 PM
  #71
K51's Avatar
K51
Too bad Griot's Garage no longer sells their wheel restoration kit, as it was the closest to an OEM finish I've ever seen. It was a great kit for ~$50, and I wonder why it's NLA.
Old May 8, 2013 | 07:16 AM
  #72
CadGeek's Avatar
CadGeek
I used Duplicolor Shadow in my stock chrome ones. I'm happy with the results.
Attached Thumbnails DIY: Painting your stock rims-298295_10151403929430689_1796416575_n.jpg
ablaine
Nov 29, 2016 10:13 AM
