Sparco Harness Bar. DIY Installation.
Old Feb 8, 2010 | 03:58 AM
  #41
ChinaClipper's Avatar
ChinaClipper
Good writeup with good hints to help my Sparco install. I added some clear bra film to the outboard side of each mounting bracket so the bracket would not scuff the plastic interior trim plastic. I also could not get 3/8ths washers to work with my mounting bolts (hole too small), but my very early production 2003 model has some unusual specifications different than later production Z33s, such as smaller front strut bar mounting bolt diameters. Good information and informative pix Vo7848.
cheers,
ChinaClipper
Old Feb 8, 2010 | 12:37 PM
  #42
VO...'s Avatar
VO...
Administrator
cheers,
ChinaClipper
Glad I could help...
Old Feb 8, 2010 | 01:02 PM
  #43
RandomHer0's Avatar
RandomHer0
Is anything special needed to use the OEM belt/buckle with aftermarket seats?
Old Mar 16, 2011 | 08:27 PM
  #44
shakuya88's Avatar
shakuya88
I've heard some people say yes and others say no. Would this bar fit in a G35 coupe? The B-pillar shape looks identical so the bracket will fit most likely, my question is are the wide of the b-pillars from drivers to passenger side the same.
Old Oct 12, 2011 | 09:57 AM
  #45
Z31KID's Avatar
Z31KID
Originally Posted by =Cerberus=
So the sparco bar does not use any additional bracing to keep it from bending up or down?
Does this pose any kind of problems? Under performance driving does it move when it's under stress or anything. I think someone said something about putting some kind of protector beneath the b pillar where it's mounted so it doesn't move? Sorry I know this is an old thread just considering a bar now! Lol
Old Oct 12, 2011 | 10:02 AM
  #46
ChinaClipper
No problems and hardly any movement at all. The shape of the brackets "wedges" the bar from up and down movement by pressing against the B-pillar interior plastic panels. It really does work slick, and does not interfere with rear storage space!
Old Oct 13, 2011 | 10:46 AM
  #47
Hap422's Avatar
Hap422
Default Roll bar vs. Restraint bar. Need advice please
Just picked up 2 Sparco seats and some 6 point harnesses and wondering if I should go with a roll bar or a restraint bar.
I would appreciate any advice.
Thank you.
Hap
Old Nov 3, 2011 | 01:29 PM
  #48
Z31KID's Avatar
Z31KID
nice thanks a lot chinacliper, i'm looking at either a sparco bar or a nrg bar. any thoughts? sparco i've found new for about 450 plus s&h and the nrg is only 200 haha
Old Nov 3, 2011 | 02:25 PM
  #49
ChinaClipper
I was not familiar with the NRG bar, but have checked it out and it looks substantially as stout except for the side mounting brackets to the car. The install of the Sparco is much easier than NRG - no drilling like the NRG into the rear deck! I have seen a number of other harness bar designs. I think Sparco has a superior harness bar design for the Z33. Remember that you always get what you pay for. . . . . . .
Old Nov 5, 2011 | 12:34 PM
  #50
Hap422's Avatar
Hap422
Default Harness bar
I just had the Sparco harness bar installed. Looked at NRG but went with a name I trust rather than lower price. I had to question the substantially lower price for the NRG and went with the assumption that the Sparco bar had to be the safer choice.
Old Mar 23, 2018 | 06:23 PM
  #51
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Sooooooooooo just wondering if this added any noticeable chassis stiffness?
I'm not getting any harnesses but I do like things stiff.
Old Mar 23, 2018 | 09:08 PM
  #52
ChinaClipper
Due to the fact that the harness bar installs high up on the chassis as well as picking up only two fasteners in the car (for the Sparco bar), there is no noticeable difference in chassis stiffness, that I've detected.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
