Aftermarket Hub, QR, & steering wheel install DIY
Old Dec 26, 2013 | 08:45 PM
  #41
ALO8's Avatar
ALO8
do i have horn hooked up correctly? The center tab is the hot and the outer tab in yellow i connected to the outer metal ring that also has a tab?? so basically the wire in pic connects the horn button outer tab to the metal ring tab? or does it have to be grounded to something else not the support ring? Its a momo wheel
Old Dec 27, 2013 | 09:35 PM
  #42
ALO8's Avatar
ALO8
figured out the horn setup once i read the quick release instructions. I am having trouble with the harness provided in the works bell short hub. Mine has 2 wires coming out of the harness adapter (red and black), most images show only one coming out of the harness. Is the black wire in my harness the (+) ? and if so where do i plug in the red wire?
In this DIY OP has one wire coming out of the harness and another example in the images i have has 3 wires coming out.
MY HARNESS AND HOW I PLAN TO CONNECT
SAMPLES OF OTHER HARNESS ADAPTORS
Old Dec 28, 2013 | 05:11 PM
  #43
ALO8's Avatar
ALO8
bump? im going to assume the 3rd pin black wire is the power for horn and im going to disconnect the red cable for the harness since i do not need.
Old Mar 13, 2014 | 01:10 AM
  #44
KingBaby's Avatar
KingBaby
Hardest Setting
BUMP
this setup was originally on a 03 Z and I assume working att.
pictured from left to right: [left] hub horn wires [top right] supplied work connection [lower right] is the 07/08 OEM steering wheel connection.
Installed the left and top right to have the horn intermittently work. i took it all apart and recognized the wires are different on the connectors.
Question: Would I be using the OEM connection and pairing the black and red to the hub horn's black and read?
thanks
Old Mar 13, 2014 | 08:50 AM
  #45
ALO8's Avatar
ALO8
I just used the black cable which is 3rd slot and is power wire on the work harness. That I ran to the red wire of hub. The red wire on the work harness was not used on mine. This was on an 05' base tho. Just like pics above your post
Old Mar 16, 2014 | 12:22 AM
  #46
KingBaby's Avatar
KingBaby
Hardest Setting
Thanks for the help!
I double checked my wiring which seemed to be good! Verified this back tapping the two wires together to get a honk from the horn. Once I did that, I turned to the horn button itself and made sure after connecting the steering wheel that the wires would still give off a honk if tapped together. I got a honky therefore I had to pop the button out and reseat it to make contact with the grounding ring!
Old Dec 18, 2014 | 11:03 AM
  #47
ptwinkle's Avatar
ptwinkle
Originally Posted by sdavis1090
Quick Question:
Do you know if these 2 pieces just pop off? The paint's coming off on mine and I need to refinish them.
Thanks!
Did you ever get an answer to this? Mine is an '06 same problem.
Old Jan 10, 2015 | 07:23 PM
  #48
Egunnaonahoe's Avatar
Egunnaonahoe
Default Help
I tried to take the torx screw off but it was too tight and got minor strip. What could I do?
Old Jan 29, 2015 | 07:28 PM
  #49
Swasho's Avatar
Swasho
Has any figured out the problem with the momo hub adapter?
Old Sep 14, 2015 | 08:57 AM
  #50
Gunkata's Avatar
Gunkata
Quick Question:
Thanks!
I'm looking to swap out my OEM wheel with a re-wrapped one I picked up from a guy in Germany. Did this ever get solved? as I will need to carry these over to the new one. Thanks!
Old Sep 14, 2015 | 09:12 AM
  #51
Gunkata's Avatar
Gunkata
http://www.350z-uk.com/topic/32500-h...teering-wheel/
ah, easy - answer is in here^
Old Sep 16, 2015 | 10:04 AM
  #52
pfregeolle's Avatar
pfregeolle
KEY!S Racing 330mm Deep Leather
Works Bell Rapfix II Blue
Works Bell Short Hub
Thanks for the write-up - Helped me prepare for my install
Attached Thumbnails Aftermarket Hub, QR, & steering wheel install DIY-img_4895.jpg   Aftermarket Hub, QR, & steering wheel install DIY-img_4898.jpg   Aftermarket Hub, QR, & steering wheel install DIY-img_4901.jpg
Old Sep 23, 2015 | 11:47 PM
  #53
Mikey R6's Avatar
Mikey R6
This worked great! thanks for the great write up!
No lights came on, and the horn works. I need to open it up again i think I'm going to install my cruise control again and wire into the dash.
Old Aug 23, 2016 | 08:39 AM
  #54
pfregeolle's Avatar
pfregeolle
Updated pic:
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
SharX59
Sep 27, 2015 09:23 AM
