DIY for Steering Wheel Removal and Steering Wheel Audio Control Unit Install
Old Sep 15, 2010 | 09:19 PM
  #161
ZRsaad's Avatar
ZRsaad
Default I have the steering wheel switches.. never did my upgrade
PM If you want the switches as described here.. I ordered them and never got around to installing them.... sold the ZR... I'm in Dallas area now so PM me and offer and i'll ship them out..
Old Sep 17, 2010 | 02:10 PM
  #162
SlipZ's Avatar
SlipZ
Originally Posted by gt3
8. With the steering wheel out, remove the 2 screws in back of the aluminum covers.
im currently just trying to replace the aluminum covers is the screw here just the ones i need to do and the covers will pop off??
Old Apr 5, 2011 | 08:03 AM
  #163
dfresh713's Avatar
dfresh713
Master
This is good stuff.
I've got an '05 with just cruise control and I will be upgrading to the '06+ with audio + cruise control and light illumination.
I already ordered and received the new cruise and audio switches. I'm ordering the torx bolts and 2006+ spiral cable for a plug and play installation.
I've never taken apart a steering wheel, nor do I have a the drill to take off the air bag. I'm going to work on finding someone or figure how to take it off myself.
I'll be back with an update in a few weeks on the installation.
Old Oct 14, 2011 | 12:18 AM
  #164
KingBaby's Avatar
KingBaby
Hardest Setting
Question!
Can you route a new wire through the spiral cable?
Old Oct 14, 2011 | 11:08 PM
  #165
KingBaby's Avatar
KingBaby
Hardest Setting
bump
Old Oct 15, 2011 | 04:13 PM
  #166
mackaroni's Avatar
mackaroni
08350zboy...Was it simple plug n play or was there extra wiring involved? I have all the parts, but want to make sure I'm prepared for the install. Any input or advise would be much appreciated.
Tks
Old Oct 16, 2011 | 01:16 PM
  #167
gt3's Avatar
gt3
Originally Posted by KingBaby
Question!
I never took apart the spiral cable but I would think it would not be easy.
Old Jan 25, 2012 | 08:15 PM
  #168
csufr12345's Avatar
csufr12345
Default Part number
Originally Posted by dfresh713
This is good stuff.
Do you have the part number for that?
Old Jan 25, 2012 | 08:19 PM
  #169
csufr12345's Avatar
csufr12345
Default Radio switches
Originally Posted by 08350zboy
Is the spiral cable needed for the illumination? is this needed on a 08 350z since it's supposely prewired for the wheel mounted controls?
I want to do this upgrade but want to make sure I don't need anything else is needed to make controls illuminate.
Thanks
1 x Cruise & Audio Switches (25550-CF40A)
2 x Replacement Air-bag Torx Bolts (87850-89900)
1 x 2006+ Spiral Cable/Combination Switch (25567-Z33003)
(above taken from courtesy parts) NEEDED? FOR 2008 350z?
For unknown reasons the radio switch were not working on my 06Z. I replaced them w/ new ones and still they did not work. I live in LA and was wondering if you can help me out? I know nothing about cars.
Old Jun 2, 2012 | 07:47 PM
  #170
Luminair's Avatar
Luminair
I have an Enthusiast '03 with cruise control - there seems to be some conflicting information here. If I wanted to do this, what would be the simplest way to accomplish the modification? Illumination doesn't really interest me.
Old Dec 18, 2012 | 03:36 PM
  #171
jarrettgt's Avatar
jarrettgt
Originally Posted by JDub03
so i stripped the tamper proof torx bits. how the f**k do i get them out now?
Same thing just happened to me and I had to post-pone the install. I got the first one out okay, but i completely stripped the second one and had to stop. Any ideas how to get it out? Would greatly appreciate it, so I don't destroy my car in the process.
Old Dec 22, 2012 | 07:48 AM
  #172
jarrettgt's Avatar
jarrettgt
Well, thanks for the help. I ended up bending the bracket inward and I have no idea how to bend it back so I can access the bolt. May be time to take it to a shop...
Old Feb 18, 2013 | 02:37 AM
  #173
shyun1250's Avatar
shyun1250
Hey guys,
Reviving the thread.
Quick question:
I have an 03 touring Z. Would it be possible to buy an 06+ steering wheel with both Cruise Control and Volume control and simply swap the wheels and wire everything up?
I plan on doing so with the pac controls and an aftermarket pioneer double din.
I would just like confirmation before proceeding.
Thanks.
Old Feb 19, 2013 | 12:52 PM
  #174
Integra9023's Avatar
Integra9023
Originally Posted by shyun1250
Hey guys,
Quick question:
I have an 03 touring Z. Would it be possible to simply buy an 06+ steering wheel with both Cruise Control and Volume control and simply swap the wheels and wiring everything up?
Thanks.
Good Question! ^^^^ Or can I buy the steering wheel controls and retrofit them on my 2005 35th Anniversary with the factory nav and factory radio????
Old Feb 20, 2013 | 04:01 PM
  #175
shyun1250's Avatar
shyun1250
Hey guys,
Quick question:
Thanks.
Baaaamp
Old Feb 28, 2013 | 02:06 PM
  #176
shyun1250's Avatar
shyun1250
Hey guys,
Quick question:
Thanks.
Anyone?
Old Jun 2, 2013 | 01:34 PM
  #177
tony530's Avatar
tony530
well I Updated my steering wheel on my 2003 track with cruise, no radio control on mine. Updated to a 08 GT with radio and cruise, But no illumination or the radio don't work. The cruise control does work......
Old Jun 3, 2013 | 01:07 AM
  #178
amr_electron's Avatar
amr_electron
The 03 didn't come pre-wired for audio control, You will have to add & run the wires yourself from the spiral cable connector to the stereo .
Old Nov 8, 2013 | 05:09 PM
  #179
fkakarZ's Avatar
fkakarZ
Originally Posted by markoware
I ended up using the pins from an old alarm harness I never used, and they worked fine, too.
I installed the 06 Z audio controls in my 05 and used the SWI-X. I was able to get the lighting to work, and the cruise works fine (interestingly, the cancel and on/off buttons are swapped on the 06, but they work as labeled...I never liked how the original controls were layed out).
I used the lighting wires (there are 2, one supplies power and one controls the ground resistance for the dim level) at the VDC off switch. If someone had a base model, then I think the radio would be the easiest secondary place to get to tap the 2 lighting wires.
Now, the one issue I ran into is that the 05 spiral cable has 7 pins, whereas the 06 controls have 8 wires (the plug is the same, it is just short a pin). With the SWI-X, one wire from the steering switch must be grounded, so I grounded it to a screw in the steering wheel. I noticed the steering wheel tested as a really bad ground, so it does not surprise me that my SWI-X is a bit inconsistent in operating right now. I ordered the 2006 spiral cable on Monday ($30 from the dealer), which I assume will have 8 pins instead of the 7 I have now, so I can run the ground through the spiral cable and ground it properly in the dash. I hope that is my issue, at least.
Either way, the 06 controls look nice with the lighting.
Whats up I recently got an 08 steering wheel and installed it into my 03 z with cruise control and the cruise control works perfectly, i have not installed a pac controller so my audio controls are not working yet,
But my question is how do i get the Lighting to work, I really want the control to light up, I swapped both the CC and Audio Controls from the 08 wheel to my 03 Wheel
Old Jan 2, 2014 | 09:15 AM
  #180
Meeerrrk's Avatar
Meeerrrk
I know this is an old thread, but just wanted to say thanks to you and also "aust350z" for the instructions and help to get this done.
I'm in the UK with a 2005 uk gt spec car - it had cruise but no steering radio controls.
So I read your guides in detail, Got the trim with the steering buttons 2nd hand and got stuck in. Luckily, my car was pre wired from the spiral cable to the radio, so once I had added the buttons to the steering wheel, putting the pins in the right position in the connector behind the airbag (in the steering wheel) and put it all back together, it worked!
These are non illuminated, as it would have been from factory in 2005. Really pleased so thanks for your help guys
