Designed a way to mount tire pressure sensor to any wheel....
Old Jun 2, 2003 | 09:13 AM
DrCold's Avatar
DrCold
Very sweet! That looks damn good.
I'll be doing this same setup when my GT-C's get here. Thanks a million.
Old Jun 3, 2003 | 05:11 PM
slay2k's Avatar
slay2k
Speaking of sensors.. I've got some up for sale now in the classifieds section, PM if interested. Thought I'd throw in a shameless plug
Old Jun 4, 2003 | 09:24 PM
daytona350z's Avatar
daytona350z
are you selling these kits?
how much do i have to pay you to make a set for me?
thanks
Old Jun 8, 2003 | 08:30 AM
geezer902's Avatar
geezer902
Default Want to make sure
....before I go through the work -- you do have to remove the valve stem and leave it out? Right? (The question is dumb, I know, but I don't know how the TP sensor works.)
Old Jun 8, 2003 | 03:03 PM
BZNYA's Avatar
BZNYA
The sensor and valve stem are one piece, I had them replaced with standard valve stems on the stock wheels.
The kit is fairly simple to make, however I would need several people's interest in it in order to invest in the materials to make for sale.
Old Jun 9, 2003 | 07:59 AM
DrCold's Avatar
DrCold
You can count me in on a set. Hopefully my GT-C's will be here in a month or 2.
These seem pretty simple to make, but then again, im just too damn lazy.
Old Jun 13, 2003 | 11:46 AM
TRACK350z's Avatar
TRACK350z
Lightbulb
The sensors fit the GTC, why go through all that trouble just to add weight!!
Old Jun 23, 2003 | 11:00 AM
Fuelish350's Avatar
Fuelish350
Hi,
What your doing does work, this is what I had to do on my 2002 corvette. I had set of 20" HRE wheels put on and we had to do the same set up. Make sure you use some 3m double sided tape along with the clamp!
Old Jun 25, 2003 | 07:12 PM
Redfoot's Avatar
Redfoot
Question
What is to stop this setup from rotating? Accelerating, Decelerating, just plain driving with all the viberations/gyrations involved how long will it be before things have changed just slightly enough to be out of balance? You are just relying on the friction of the band to keep this setup from moving along the groove..... This thread is old enough for some feed back, Is it still working????
Old Jul 10, 2003 | 09:06 PM
kozik's Avatar
kozik
why not just epoxy them in place?
Old Jul 13, 2003 | 12:05 PM
Eric1h's Avatar
Eric1h
so, are you willing to sell these yet? and do they still work ok?
i think the 3M tape would be a great idea, along the band
Old Sep 4, 2003 | 10:05 PM
zoasis's Avatar
zoasis
You could also do this with those massive HVAC wire ties along with some double sided tape. I'm getting ready to mount some sensors in my new I-forged Aero's.
Old Sep 5, 2003 | 03:40 AM
AndyB's Avatar
AndyB
Default tape
I wouldn't use tape.
The combination of heat (hot roads in the summer) and vibration are likely to bust the tape loose. Just my opinion of course.
These band clamps seem like a great idea. Very secure and long term.
Can you get the clamps in chrome?
Old Sep 5, 2003 | 06:45 AM
BrImSt0ne's Avatar
BrImSt0ne
i have the enthu model which didnt come w/tire pressure monitors. if i install a set of tpm's will i have to buy a new gauge or will my gauge automatically start reading it?
Old Sep 5, 2003 | 11:18 AM
Eric1h's Avatar
Eric1h
anyone wanna make and sell me a set of th abands?
Old Sep 10, 2003 | 06:52 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
it doesn't look to hard to make, but not sure if I have the time to do it while the tire changer is waiting for me.. they'll have to remove the stock wheels/tires, remove the tps, then hand it to me, then I would have to mount the sensor right there on the spot, and then give the new wheels back to the tire changer, so they can mount the tires..
wish there is an easier (faster) way..
epoxy would be good idea, but it takes time to cure..
Old Sep 11, 2003 | 07:04 PM
abogada001's Avatar
abogada001
Default What about balancing???
What about balancing aftermarket rims after the tires are mounted, is this much of an issue?
Thanks
Robin
Old Sep 14, 2003 | 05:15 PM
  #38
flynnibus's Avatar
flynnibus
Z Flier
The system is more then just the sensors in the tires... the reciever is probably missing from your car as well.. just putting the tire portion in probably will not do you any good. There is a whole module in the car that does the recieving of the signals from the units in the tires and sends that info on to the ECM.
Old May 30, 2007 | 05:30 PM
  #39
smartparts15's Avatar
smartparts15
Just an FYI if you ever need your tires dismounted, make sure to tell the person whos doing it for you what you did with the sensors! Last week a guy came in with a caddy on 20's and did almost the samething as this, the tech taking off the tires broke 2 sensors, those ones were ~500$ a piece(charged to the customer) so be careful, and let the guys know dismounting your tires that you mounted them on the tire drop section.
Old May 30, 2007 | 06:25 PM
  #40
zand02max's Avatar
zand02max
This thread is over 4 years old!
