sagging eibach springs..
hey guys,
i put on my eibach springs on maybe 10 months ago. I recently noticed that the back right is lower than the back left.
what can be attributed to this ? What should i do to fix this??
any info would help. it is really starting the bother me.
mine did the same thing for awhile, but is back to normal. I didn't do anything to it, so i'm not sure what caused it, but the back right definitely looked lower by 1/2 inch. The only other reason i could think of is a blown shock, but mine is still stiff in that corner. Once you blow a shock, it usually settles half an inch from the loss of gas pressure, but you would have an oil leak out of that shock as well. Maybe try jacking that corner up and turning the spring a little and let it settle down again, maybe it shifted in a weird way when it settled in? Good luck, let me know if you find out anything.
seagrasser
Oct 11, 2015 03:27 PM
