GT Spec braces
Old Feb 25, 2005 | 06:45 PM
jcpeyton's Avatar
jcpeyton
Default GT Spec braces
Has anyone installed the GT Spec front lower brace/rear lower tie brace/rear lower lateral reinforcement brace? Whaddya think? Also, does the rear lower lateral tie brace interfere with the nismo catback exhaust?
Old Feb 26, 2005 | 02:22 PM
jrotaryb's Avatar
jrotaryb
Old Feb 26, 2005 | 06:03 PM
ZinMiami's Avatar
ZinMiami
Default Re: GT Spec braces
I bought all 3. The lateral reinforcement brace does not fit with a Fujitsubo cat back which is very simialar to the Nismo so that probably will not fit either.
It will fit if you force it a bit but it rubs against the mid-pipe causing all the rumble to resonate throughout the cockpit. It was unbearable.
The shame of it was that the lateral brace appears to make the most difference. When I added it I could tell it was there moreso than with just the other 2. When I took it off I could realy notice that as well.
Old Feb 26, 2005 | 10:58 PM
axxizzer's Avatar
axxizzer
are they lighter than stock like the STi ones?
Old Feb 27, 2005 | 05:46 AM
ZinMiami's Avatar
ZinMiami
Stock?????
These are additional braces. There is no stock equivalent. If you do a search on gtspec braces you will find many pics of the braces.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
