ACP camber kit?
Old Mar 3, 2005 | 10:29 PM
OvaYahead's Avatar
OvaYahead
Default ACP camber kit?
Has anyone heard of ACP? It's not a bad price, just kind of odd that they look like stillens rear camber arm.
acp kit
Old Mar 4, 2005 | 05:47 AM
Zivman's Avatar
Zivman
Default Re: ACP camber kit?
acp kit
If you are looking for camber arms, I would recommend an SPC kit. You are going to want the toe kit in addition to the camber arms, and the SPC kit includes them in their kit. I was able to find it for 219 shipped
Old Mar 4, 2005 | 06:03 AM
Road Warrior's Avatar
Road Warrior
that looks exactly like the stillen....wtf
spc definately cheaper.....219 shipped including toe bolts
Old Mar 4, 2005 | 06:14 AM
sofakingdope's Avatar
sofakingdope
anyone have a link for the SPC kit?
Old Mar 4, 2005 | 06:22 AM
Alberto's Avatar
Alberto
Cranky FI Owner
www.iapdirect.com -I just ordered my SPC stuff from there, same price as on their website. I got my toe bolts in 3 days.
Old Mar 4, 2005 | 06:33 AM
sofakingdope
It appears as though the SPC kit is only for the rear? Is there a different kit that you need for the front?
Old Mar 4, 2005 | 06:36 AM
Alberto's Avatar
Alberto
Cranky FI Owner
IIRC I remember seeing that they offered something for the front suspension, maybe some adjustable eecentric bolts? Or you could just bite the bullet and buy the 350 EVO adjustable control arms, they look like works of art. Or you could save money and buy some inexpensive Kinetix control arms for the front-but Ive heard they make noises, and I personally dont like the looks of them.
Old Mar 4, 2005 | 06:39 AM
sofakingdope
wow!! 850 dollars for control arms!! there has to be a cheaper way to fix tire feathering. That is really the only reason I need to adjust camber in the front.
Old Mar 4, 2005 | 07:00 AM
westpak's Avatar
westpak
SFZCC
I got excited just to see that it was for the rear, haven't found anything cheap for the fronts.
A while back like 1 1/2 years someone ordered bolts/spacers that adjusted the front from Australia, I can't remember what happened to that.
Old Mar 4, 2005 | 07:02 AM
Zivman's Avatar
Zivman
You really don't need these kits unless you dropped your car. They really don't do anything in regards to fixing the tire feathering on a stock car as far as I know.
The only options for additional adjustability for the fronts that I have seen are the kinetix and 350Evo control arms
Old Mar 4, 2005 | 07:08 AM
westpak's Avatar
westpak
SFZCC
I take it back, their kit is 625 so not much cheaper.
http://www.k-mac.com.au/makes/nissan.htm#tri
Old Mar 4, 2005 | 07:12 AM
sofakingdope
My car is lowered. I have the Nismo S-tune suspension. So I guess my only option is the kinetix or 350Evo. Man I cant believe that it costs so much. I had a 96 eclipse that I lowered and a camber kit for that car only cost me like 100 bux.
Old Mar 4, 2005 | 07:26 AM
westpak's Avatar
westpak
SFZCC
I did my 300Z with an 85 dollar kit and the camber is perfect. The problem is the construction of the arm and how it hooks to the car. The 300ZX is able to just put some spacers between the arm and the car to push out the top and therefore reduce the camber but the way the 350Z arms connect to the car that is not possible.
Old Mar 4, 2005 | 07:39 AM
sofakingdope
thanks for the info guys
Old Mar 4, 2005 | 07:54 AM
neur0sis's Avatar
neur0sis
Does anyone have a writeup on installing the toe bolts? Are there instructions that come with them?
Old Mar 4, 2005 | 07:57 AM
Gators2001's Avatar
Gators2001
I thaught the Nismo suspension didnt cause a problem w/ the camber.
I thaught i read somewhere that the camber problem only appears when you go lower then an inch.
Old Mar 4, 2005 | 09:35 AM
sofakingdope
I have no idea. Only had the car since monday. It was previously installed on the car. When I had the car on a lift last there was noticeable tire wear on the inside of the front tires.
Maybe I dont fully understand the "tire feathering" issue. Doesnt it occur on stock suspension set ups as well as when the car is lowered?
Old Mar 4, 2005 | 10:48 AM
Gators2001's Avatar
Gators2001
from the little I have read the tire feathering is seen on the 18' factory rims setup with even stock setup.
But as far as the nismo suspension.
If you have the Nismo (0.8 inch drop) suspension you should be within spec for the CAMBER. so no need to adjust it, unless ur a track man and want to twick your setup.
If you go more agressive w/ more then a one inch drop. then you have a camber issue. (top of the tires lean in)
I hope I help some.
Old Mar 4, 2005 | 11:19 AM
sofakingdope
It does help. Thanks Gators!!!
Old Mar 4, 2005 | 11:43 AM
OvaYahead's Avatar
OvaYahead
yeah thanks everyone for turning this into a "what camber arm to get" that was how I found this acp one.
I wanted to wait for the hotchkis set, but I guess i'm just going to get the SPC's from ebay (search "g35 350z camber").
