My alignment after Tein S-Tech
Old Mar 15, 2005 | 03:55 PM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
Default My alignment after Tein S-Tech
I just got back from Les Schwab to do an alignment and just as I expected. The rears are put back into spec by adjusting the toe bolt. They couldn't do anything for the fronts since it wasnt adjustable. So I got stuck with a -1.6 degrees in the front left. The front right seems ok. The rears was set to a -1.6, which was right in the middle. here is a pic of the printout they gave me with the before and after adjustments.
What are your guy's comments on my printout?
Old Mar 15, 2005 | 04:31 PM
tractng's Avatar
tractng
Default alignment
Hey,
Do you have any scratches on the rims after the alignment? I am going to get an alignment soon. I got the hotchkiss springs.
Tony
Old Mar 15, 2005 | 04:54 PM
hndumafia's Avatar
hndumafia
man i just got an alignment with my hotchkis springs, which as far as i know are about the same drop as the s-techs and the guy who did the alignment, who is supposed to be very good (though he works mostly with honda and acura - since actually he works at the acura dealership) couldn't get the rear camber right on either side and couldn't get the rear toe on the right side. maybe i need to go back and tell him to mess with the toe bolt. the way my camber is now my tires are gonna wear super prematurely and that wouldn't be good for my new s03s because they definitely weren't cheap.
my front is basically the same as yours except the camber is off on the right side for me instead of the left.
your alignment is looking good though - way better than mine that is for sure!
Old Mar 15, 2005 | 05:49 PM
mlg9770's Avatar
mlg9770
ZEnclosures
I have been looking for springs. I want my car lowered around an inch but .7" might work. How noticable is the drop with the s-tech?thanks mike
Old Mar 15, 2005 | 07:37 PM
cquence 350 [Z]
The Tein S-Tech's are not real noticeable. It is subtle and not an extreme drop. Search for one of my threads and you will see the pictures of the drop. As far as scratches, there was none. He did a good job and I specifically told him that my rims are VERY expensive and if he can be very careful with them. He did and so did the guys who did my balancing of my tires. I took it to Les Schwab, they are great and people friendly. The whole time I was in the shop, they were talking about my car and the turbos! Which made time go by faster since I am there supervising the process.
Old Mar 15, 2005 | 07:38 PM
cquence 350 [Z]
I am sure they can fix the rears. The guy loosened the toe bolt and adjusted the toe perfectly to spec. So the rears dont need no camber kit unless your drop is real low.
Old Mar 15, 2005 | 07:53 PM
tractng's Avatar
tractng
cquence 350 [Z] ,
How long was the alignment process? I am planning cause i have to go straight to work.
Tony
Old Mar 15, 2005 | 07:54 PM
hndumafia's Avatar
hndumafia
took about an hour and a half for me.
Old Mar 15, 2005 | 08:31 PM
hutchdelrosario's Avatar
hutchdelrosario
wats up 350z afficionados,
did you guys have to get a camber kit? i dropped my an inch with tein flex and my alignment is not correct afterwards. shops were sayin that i need a camber kit and cost about $1000-$1500 for front and back... is that right?
can it be align right without having to get the camber kit???
pls. help me with a solution to this issue.
thanks.
Old Mar 15, 2005 | 08:47 PM
cquence 350 [Z]
the rears you dont need a camber kit only the front. But since you dropped yours 1", I wouldnt know since mine was only .6" with the S-Tech. The alignment took about an hour for me.
Old Mar 15, 2005 | 08:56 PM
hutchdelrosario
which camber kit did you go with? and how much?
Old Mar 16, 2005 | 01:04 AM
cquence 350 [Z]
I havent gotten a camber kit yet. looking to get a set in the near future.
Old Mar 18, 2005 | 11:52 AM
cquence 350 [Z]
does anyone know if the fronts can be corrected a little more?
Old Mar 24, 2005 | 11:27 AM
Z_U_NVYN's Avatar
Z_U_NVYN
Hey CQUENCE_350, Which LES SCwab did you go to? I'm in SACTOWN TOO! I"m getting my HKS coilovers put on by the end of the week or next. I was going to take it to the old G12 on 16th street but I heard from someone that they couldn't get his car corrected enough. I know that Performance Techniques sends their cars there for alignments. I want my car lowered but I don't want to get a camber kit if I don't have to.
Old Mar 24, 2005 | 12:37 PM
cquence 350 [Z]
I went to the one on Northgate Blvd. Where is Performance Techniques at? And what do they do there?
Old Mar 24, 2005 | 12:44 PM
Z_U_NVYN's Avatar
Z_U_NVYN
Cool....I live right off of Truxel so that's pretty close to me. Performance Techniques used to be called Z Car Specialties and specialized in performance parts for the Z's but has expanded much since then. I think they do body kit mostly now.......haven't been there since I had them do work on my Maxima and that was like in 1988. I know the Owner has a Black G35 w/ Axis Hiro's on it. How much did your alignment run you?
Old Mar 24, 2005 | 12:45 PM
Z_U_NVYN's Avatar
Z_U_NVYN
Here's their location:
PERFORMANCE TECHNIQUES 108 OTTO CIR, SACRAMENTO, CA 95822 Phone: (916) 422-4222
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
