Sway Bar InstaLL!!!
Old Mar 16, 2005 | 09:40 AM
bstansbu's Avatar
bstansbu
Default Sway Bar InstaLL!!!
Hey guys. Pretty sure im going with the Hotchkis TVS1 kit springs/sways. Ive heard from 2 different retailers that give me different info on drop height. I want less than an inch drop, im pretty sure their springs will be less. Anyways, How difficult is the install for just the sway bars front and rear? Can any tire/brake/shock shop install those? BEN
Old Mar 16, 2005 | 09:42 AM
mojo powered's Avatar
mojo powered
they should be able to... if you're thinking about installing them yourself, there is an excellent write up on the ZchickZ website for the 350evo sways.. it should be pretty much the same procedure.
http://www.zchickz.com/evo-sway1.htm
Old Mar 16, 2005 | 09:47 AM
bstansbu's Avatar
bstansbu
Default cool
Thanks for the site link. Did I mention I have trouble hooking jumper cables to a battery. Dont think I would trust my mechanic skillz on my Z. Ill check it out though. Thanks again. BEN
Old Mar 16, 2005 | 06:07 PM
MY350Z.COM's Avatar
it's very easy, there's also a lot of room to work under the z. it took me less than an hour to do the front and rear.
Old Mar 16, 2005 | 06:36 PM
SungNamZ's Avatar
SungNamZ
The write-up in the "Garage" section of ZChickz is excellent. Used their write-up installing Koni' Shocks, Eibach Springs and 350EVO Sways. Christi had her act together and made my job easier.
hulkout
Apr 28, 2017 09:00 PM
