Alignment settings on HKS Hypermax suspension
Old Mar 31, 2005 | 12:35 PM
Fab_vr6's Avatar
Fab_vr6
Default Alignment settings on HKS Hypermax suspension
Hi all,
I am going to have a local shop install my coilovers next week, however after reading some posts from this board, I am alittle confused as to whether I will need a camber kit in order to keep the alignment setting close to factory. What if I don't buy a camber kit, what will happen?
Another question is if I play around with the height settings, is it something I can do myself in my garage? If so, will it affect my alignment settings?
Thanks for the reply!
Gary
Old Mar 31, 2005 | 02:37 PM
SkyMan's Avatar
SkyMan
An alignment is needed after each height adjustment (Adjusting is very easy). You will definetly need a camber correction kit in order to bring everything back to spec. Without a camber kit, you will experience inside tire wear.
Old Mar 31, 2005 | 02:55 PM
Fab_vr6's Avatar
Fab_vr6
IF I don't run a camber kit, how much negative camber will I be getting? What is a bearable camber setting w/o a camber kit considering tire wear...etc ? After all, having a little negative camber is good for sports/autox/track day driving isn't it?
Old Apr 1, 2005 | 07:17 AM
rednezz's Avatar
rednezz
It all depends how much you drop your car. You should still be ok if drop from 0" to 3/4". If you drop more than 3/4" you alignment will not be able to go back to stock settings. I dropped my car 1" in front and 3/4" in the rear and my front has -1.5 in camber. My rear is still in spec and has a -2.0 in the rear.
