350evo sway ?s
Old Apr 24, 2005 | 05:19 AM
Anomaly460's Avatar
Anomaly460
Default 350evo sway ?s
Wheres the best place to get a set?
My suspension is totally stock. Would i be able to feel a noticeable difference in handling with just the sways?
TIA
Old Apr 24, 2005 | 05:25 AM
zzzya's Avatar
zzzya
www.350evo.com You will feel less body roll going into turns and also have the ability to adjust the sways to your liking.
Old Apr 25, 2005 | 09:53 AM
G3po's Avatar
G3po
Default 350EVOs
TIA
I used them back when my suspension and tires were totally stock,
With both front and rear set to medium, the car was nearly perfectly balanced between under/oversteer and turn-in was far crisper.
I still run them but have much wider tires at 265F and 295R.
At the same med/med setting the car slightly understeers again.
I'm adding coilovers , so I haven't re-tuned yet.
Old Apr 25, 2005 | 08:20 PM
jcpeyton's Avatar
jcpeyton
Checkout the competition before you buy. There is a really helpful summary on sways posted recently (do a Forum search). Also, checkout Prothane for bushings.
Hotchkis, Stillen, nismo--lots of options.
I've run Stillen (reds) for about 5K, w/ Prothane bushings, and couldn't be happier. I do not track my Roadster--just play on the weekend twisties. Decide what you plan to do, and buy/adjust accordingly. Don't forget shocks/springs if you're REALLY serious. (keep in mind the angle of your driveway).
Wheels & rubber can make a HUGE difference. I run Enkei RP03 staggered w/ 245f/275r; 9" fronts & 10" rears. Where and how you spend your money should depend on what you want to achieve.
hulkout
Apr 28, 2017 09:00 PM
Paul.
Oct 16, 2015 07:34 PM
RiujinZero
Sep 25, 2015 01:19 PM
