Quick camber noobie question...?
Old May 3, 2005 | 07:20 PM
350Mark's Avatar
350Mark
Default Quick camber noobie question...?
Before I added my system to my car I had a loose 3 finger gap in the rear. After the addition of my system, I now have a tight 2 finger gap. Obviously the front hasn't changed. Before the install I wanted a minor drop using the Hotchkis springs. Basically my question is, will the added weight in the rear add to negative camber in addition to the negative camber i'm going to have with the hotchkis? Does that makes sense? One more question. I still want to lower the front so I was wondering if I could just use the Hotchkis in front and oem in the rear? Is that possible?
Any help is appreciated!!!
--Mark
Old May 4, 2005 | 06:18 PM
350Mark's Avatar
350Mark
Anyone?
Old May 4, 2005 | 07:10 PM
JimRHIT's Avatar
JimRHIT
I wouldn't use just the front springs. I use the hotchkis front and rear springs ... plus I have 2 12s and a fiberglass box in the back ... here is how my car sits.
To answer your question ... yes, it will add more to the camber problem ... but not significantly more ... it is fixable withing factory spec.
-jim
Old May 5, 2005 | 12:44 AM
350Mark's Avatar
350Mark
Thanks Jim! Your car looks badass and that drop is perfect! Looks like you have no wheel gap.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
