Lowering the Z???
Old May 28, 2005 | 05:14 PM
Mrbig's Avatar
Mrbig
Default Lowering the Z???
I was told by a few people that you can add just a set of eibachs with stock shocks and the car will ride fine and handle very well with added struts bars and sways as well, what do you guys think ??? Plus it will add a nicer look to the car !!!
Old May 28, 2005 | 05:16 PM
westpak's Avatar
westpak
SFZCC
Yes and the Z already has strut bars.
Old May 28, 2005 | 08:53 PM
illudezion's Avatar
illudezion
i just have eibachs sportline springs and i think i make a world of a difference
Old May 28, 2005 | 09:31 PM
Mrbig's Avatar
Mrbig
Thumbs up ???
Thanks for the info i guess thats the thing to do if crazy handling isn't your thing ...lol.....
Old May 29, 2005 | 05:44 AM
zzz350's Avatar
zzz350
Do the eibach sportline springs make the ride very rough? I don't race it or track it, so I don't need to overdue it and make it more bumpy if I don't have to, any advice. I am going to put some 18" (same reason) instead of 19", but I need to lower the z by .75" to 1".
Old May 29, 2005 | 07:02 AM
MethodRN's Avatar
MethodRN
For Sale
that much of a drop and you're looking into investing in a-arms and rear camber kits. Think about hotchkis, good even drop, stock if not better ride, designed w/ stock struts in mind, good price and if you go w/ TVS 1 kit you get some awsome sway bars.
Old May 29, 2005 | 07:10 AM
westpak's Avatar
westpak
SFZCC
The ride is very good with the Eibachs not rough at all, but I would add a set of Tokico's I just did and the ride was amazing, they are adjustable and if you do not want to adjust them just put them on 3-4 turns from firm and you will get an amazing smooth ride and still handle great, they are not that expensive either and if you do the springs at the same time only additional labor is for the rears which is minimal.
Old May 29, 2005 | 07:51 AM
Mrbig's Avatar
Mrbig
Default Hotchkis Springs ???
Who has these any pics and how do they do with stock shocks over the eibachs ??? Also how is the Stage 1 kit they offer (Hotchkis) ???
Old May 29, 2005 | 04:36 PM
zzz350's Avatar
zzz350
Thanks for the info, I want to seriously look into this.
Wpak,
Are Tokico's adjustable shocks? You suggest I go with Eibach springs and Tokico adjustable shocks, Correct?
MethodRN,
I'm not sure what to even ask for to make the changes you suggest, can you be specific, I'm a nubie on mods.
Thanks both of you guys.
Old May 29, 2005 | 07:26 PM
KManZ's Avatar
KManZ
I just had the TVS kit installed Friday, and so far it is great!!! The drop is subtle, yet noticable: the gap on my 17" rims is much cleaner looking now.
The ride is a little stiffer, which is a good thing: The hopping from the stock suspension is all but gone! And around corners the car is on rails! Definately a sweet mod, and very inexpensive too.
I will snap some photos tomorrow for you all.
Old May 29, 2005 | 07:31 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
+1
That's what I'm running & their great (Actually running the TVS Stage 1 Kit: Hotchkis Sports Springs + Adjustable Sways). Other springs out there will cause your camber to be out of spec & the only way you'll put it back is for aftermarket camber arms. With the Hotchkis, the drop is just right that you won't need to buy them. Don't remember the actual drop but I believe their about .8" drop. But then again, this is also about personal taste as well so maybe you'll want to run lower than that.
Old May 29, 2005 | 07:49 PM
westpak's Avatar
westpak
SFZCC
Wpak,
Yes they are adjustable, the fronts are easy to get to in the engine compartment but the rears you have to jack the car up and pull the two bolts holding the shock in place and pull it down for access to adjust, which is not too bad and if you are not going to playing it all the time then it is fine and for that small inconvenience I would rather get them than pay for the Koni's which I hear are easier to adjust in the rear but cost a bit more.
I have the Eibach/Tokico combo and love it, right now I have them on 4 turns from firm which made it extremely comfortable for the 800 mile ride to Zdayz and it still handled the Tail of the Dragon fine. I just had the car aligned and my camber was -1.8 and -1.6 in front which is just out of spec which the max is -1.3 my caster was also just slightly out at 9.1 and the limit is 8.9 the toe was 0. The rear was also out but a little more at -2.8 and -2.4 where the max limit is -2.1, this has not been an issue in the rear before as I wear out the tires before any effect of the camber is noticeable
Old May 30, 2005 | 06:22 AM
zzz350's Avatar
zzz350
Thanks for the info you guys, now I have some idea what to be looking for. If you suggest any websites to obtain this set up, let me know. Or do I just go to someplace like performance nissan?
Old May 31, 2005 | 08:57 AM
MethodRN's Avatar
MethodRN
For Sale
Lots of great advice given so far. Again it's all about personal tastes. A little more aggressive drop w/ the eibach, can't comment on ride, great spring from what I've heard. My car is a daily driver and didn't want too low of a drop so that's why I went w/ hotchkis. Also considered Tein S-tech at the time. As for the shocks, the tokico is what I'm gonna go w/ when the time comes. As for where to get the hotchkis, I usggest looking at GSC motorsports. Great price and service. Also check out Caliente motorsports. GOod luck
Old Oct 12, 2005 | 09:57 PM
overboostedtoy's Avatar
overboostedtoy
do you have the pro-kit or sportline?
Old Oct 13, 2005 | 03:35 AM
westpak's Avatar
westpak
SFZCC
Prokit and I just broke down and got the Kinetix full package to correct alignment.
Old Oct 13, 2005 | 07:53 AM
overboostedtoy
was the rear toe within spec after the drop? if not, were you able to adjust it to spec. I'm debating between sportline and pro-kit. cuz what I heard the sportline wont be able to set the rear toe within spec. that's why I'm aiming for pro-kit. I had Eibach and Tokico shocks on my previous vehicle and it was a good combo.
Old Oct 13, 2005 | 12:52 PM
westpak's Avatar
westpak
SFZCC
The rear toe was within spec and the camber was just out by about 0.2 degress, I could have left the back alone but I want to straighten it out a bit for better tire to road contact for the drag strip I am basically not using the outside 1 inch of the tire.
May 30, 2017 03:28 PM
James1990
Dec 16, 2015 08:57 PM
