Tein Flex need new control arms?
Old Jun 24, 2005 | 07:46 PM
Mr_Q's Avatar
Mr_Q
Default Tein Flex need new control arms?
Was wondering if the setup would require new control arms to help get he camber/caster set happily.
Or can you get "close enough"?
Old Jun 24, 2005 | 08:09 PM
ssc's Avatar
ssc
depends on how low you go
Old Jun 24, 2005 | 08:19 PM
Mr_Q's Avatar
Mr_Q
So even the highest setting isn't too low then? That would be good. I'd like to only drop .8"
Old Jun 24, 2005 | 09:14 PM
JETPILOT's Avatar
JETPILOT
Camber on the stock arms is not adjsutable so when you lower the car the negative camber will increase. MOST LIKELY the camber will still be within limits. But it still means you are increasing negative camber.
Respect
JET
Old Jun 25, 2005 | 06:51 AM
Gsedan35's Avatar
Gsedan35
Given Tein's published min and max drop range for the Flex on a 350Z, you can set the car up with a ride height that does not require aftermarket parts to be within oem alignment specs. Staying within those specs is directly linked to how much you drop the car.
Looking at the Tein specs, Tein recommends a .9"/.8" drop, which will put you close to the max on the alignment specs, this recommend drop does reflect them corner weighing the car and the resulting drop.
http://www.tein.com/nissan.html
sales@czp
Sep 23, 2019 03:30 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
