Spring Installation
Old Jun 24, 2005 | 09:49 PM
BhashaZ's Avatar
BhashaZ
Default Spring Installation
How much would it cost to get springs installed? I'm looking for somthing that lowers around 1/2" to 3/4". I'm located in Southern California.
Also, do I need a camber kit for the rear for a relatively small drop?
Old Jun 24, 2005 | 10:03 PM
35oZephyR's Avatar
35oZephyR
You should be more than fine with those conservative numbers.
Anything over an inch or roughly 0.8 in the back and you might need the SPC camber arms/ toe kit.
Old Jun 24, 2005 | 10:30 PM
BhashaZ's Avatar
BhashaZ
Will springs start "sagging", and how long are most warranties?
Should I go with Tein-S, Hotchkis, RS-R Down?
Old Jun 24, 2005 | 11:53 PM
35oZephyR's Avatar
35oZephyR
I doubt they'll sag to the point where they diminish your ride. The names you've mention are very reputable so if any sag occurs, you could probably contact them about it.
What are you looking for?
A little Tracking, Aggressive driving, daily driving springs?
I know the Hotchki's go with the stock struts/shocks really well.
Old Jun 25, 2005 | 12:57 AM
tractng's Avatar
tractng
BhashaZ,
Hit me up for more info. I am the guy we met long time ago for the leather installed.
I have the hotchkiss and you don't need camber kits.
Tony
Old Jun 25, 2005 | 01:19 AM
pacfwu's Avatar
pacfwu
I had H&R's in my '04, and they're like a 1.5 inch drop after settling. The camber was still within factory spec. Anything lower will need camber kits though.
The springs and install were about $550 or so. But, I bought them through Les Schwab. You can get a better deal if you look around.
Old Jun 25, 2005 | 07:53 AM
BhashaZ's Avatar
BhashaZ
I am looking just to lower the car a bit to decrease the wheel gap. So basically you would categorize them as daily driving springs.
Tractng: PM'd you.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
