I need a rear camber kit, what kit to buy?
Old Jun 25, 2005 | 04:21 PM
jeffie7's Avatar
jeffie7
Default I need a rear camber kit, what kit to buy?
Pretty much as the title says. can you guys link me to one?
http://www.modacar.com/products/Nissan/350Z/MODACAK/
Is the SPC kit worth while?
thanks for any replys
Old Jun 25, 2005 | 04:32 PM
B-Unit's Avatar
B-Unit
I have the SPC kit and couldnt be more satified. its great because it has toe and camber adjustment. As the camber goes like this / the toe also moves inward, the spc kit allows you to keep that from happening. Plus its very affordible.
Old Jun 25, 2005 | 04:41 PM
JETPILOT's Avatar
JETPILOT
Depends weather you want rubber/urethatne bushings, or spherical bearings. Rubber/urethane bushings go with SPC. Spherical bearings go with 350Evo.
Respect
JET
Old Jun 25, 2005 | 05:46 PM
35oZephyR's Avatar
35oZephyR
Went with the SPC rear camber arms and toe bolt package as well.
Even my mechanically inept @ss was able to install everything. Should be a walk in the park for you, especially after your front spring episode.
The guys doing my allignment mentioned how the arms/ bolts were great quality and easy to adjust with.
Got them from here: https://www.iapdirect.com
Old Jun 25, 2005 | 05:56 PM
jeffie7's Avatar
jeffie7
Thanks for the link! cheaper then modacar. woot!
If nothing else comes up before tomorrow night I will go ahead and order them.
Thanks.
Old Jun 25, 2005 | 06:07 PM
35oZephyR's Avatar
35oZephyR
And heres for everyone else who happens to do a search:
This is so you don't have to navigate through the whole site:
https://www.iapdirect.com/item.asp?invid=622
$219 (with toe-bolts) and shipping already included (discounted) is a helluva deal!
Protocav's (chad's) install writeup for the toe-bolts.
Well-written and pretty straightforward.
Anything that inspires confidence before an install, is always good.
http://members.***.net/chadisrad/SPC.pdf
Old Jun 25, 2005 | 06:53 PM
NA&CH's Avatar
NA&CH
Iapdirect is a great company to deal with. Ordered mine got them withing the weeks end. I ordered the Spc rear kit. Havent had time to install it yet but looks like great quality.
Old Jun 25, 2005 | 07:18 PM
jeffie7's Avatar
jeffie7
https://my350z.com/forum/showthread.php?t=129434
Only problem I have with the company is the fact that they are not up to par with Mozilla...
Old Jun 26, 2005 | 07:47 AM
daytona350z's Avatar
daytona350z
www.battleversion.com
track tested...and proven. may cost a lil more than the spc kit, but quality is far greater especially with the use of spherical bearings instead of rubber bushings.
Old Jun 26, 2005 | 01:02 PM
jeffie7's Avatar
jeffie7
I like the look better even more so on my redline Z.
Just wondering. I keep hearing about spherical bearings... what does nissan use? I believe everything is bushings right?
Old Jun 26, 2005 | 01:39 PM
daytona350z
basically nissan uses rubber bushings. aftermarket like spherical bearings reduce the "slop" in the oem rubber bushings because there is no rubber expanding and contracting, thus giving "tighter" handling.
Old Jun 26, 2005 | 09:43 PM
jeffie7's Avatar
jeffie7
I just ordered the SPC kit since I think for my use the extra money isnt worth it.
plus I just orded 240 bucks worth of cooking wear from amazon.com so Im not to trigger happy on spending even more money on getting my camber right =)~
Old Jun 26, 2005 | 10:25 PM
35oZephyR's Avatar
35oZephyR
Great choice...
You WON'T be dissappointed.
They're great quality, and not the bare metal pieces you see on the japdirect website.
SPC has them powdercoated black.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
