Solutions For Rear Camber/Toe Adjstmnt 4 Lwrd Cars
Old Jun 26, 2005 | 04:58 PM
JETPILOT's Avatar
JETPILOT
Default Solutions For Rear Camber/Toe Adjstmnt 4 Lwrd Cars
I put this thread together while looking for solutions for rear camber and toe corrections for a lowered car. Here are my findings. If there are any mistakes please advise.
Rear Camber/Toe correction
SPC… Adjustable camber arm/toe bolt ($239)
Positive: Inexpensive fix for camber/toe. Improves handling in regards to the use of urethane bushings.
Negative: Rubber/urethane bushings that keep it inexpensive are not up to par with spherical bearings. They don’t manufacture an adjustable toe arm, which should be use in conjunction with toe bolt to adjust toe correctly.
JIC… Adjustble camber arm ($369)/adjustble toe rod ($496)
Positive: Spherical bearings on both the camber and toe arm are the final solution in reduction in suspension slop.
Negative: Still need to buy the SPC toe bolt ($90) to adjust the toe correctly. Spherical bearings reduce ride quality. Expensive (due to spherical bearings).
Stillen…Adjustable camber/rear toe arms package ($749)
Positive: Heim joint rod ends included with the camber rods on par with spherical bearings for ultimate suspension control.
Negative: Urethane bushings included on adjustable toe rod. Improvement over stock, but not as good as spherical bearings. Still need SPC toe bolts ($90) to adjust toe correctly.
350 Evo… Adjustable camber arm/traction arm ($1546) package complete with front upper control arms
Positive: Spherical bearings.
Negative: Traction arm is not adjustable for toe. Even when used w/SPC toe cannot be correctly adjusted.
Battle Version… Adjustable camber arm ($275)
Positive: Inexpensive, w/heim joint rod end.
Negative: still need to buy both adjust able toe arm/SPC toe bolt to adjust toe.
Hotchkis… Adjustable toe/camber arms ($?)
Positive: Inexpensive fix for camber/toe. Improves handling in regards to the use of urethane bushings. Bushings come with grease points for lubrication.
Negative: Rubber/urethane bushings that keep it inexpensive are not up to par with spherical bearings. Still need SPC toe bolts ($90) to properly adjust toe.
Did I miss any?
Respect
JET
Old Jun 27, 2005 | 10:03 AM
Darth Bobo's Avatar
Darth Bobo
Kinetix also has a rear adjustment package:
http://www.kinetixracing.com/index.a...&ProdID=4&HS=1
JjL
East Canada
Jun 12, 2019 03:04 AM
SpartanZ32
Oct 22, 2015 09:36 AM
Suffolk350z
Sep 13, 2015 02:43 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
PureR3d
Sep 10, 2015 06:23 PM
