alignment spec help
Old Jul 21, 2005 | 08:14 AM
konspec's Avatar
konspec
Default alignment spec help
I've searched to find a thread were everyone posts there alignment specs and what they use their cars for...(no dice) Anywho check my sign for suspension mods I autocross, drift and daily drive my car. Would alittle toe in the rear help traction or hurt, also whats the recomendations for rear camber? I want something more agressive then stock but that does'nt eat my tires alive.( hopes and dreams) Oh yeah my drop is about 1.4 all around. The shops i've been talking to need actually numbers to go from, they don't understand why i want a custom alignment.
thanks, late
Old Jul 22, 2005 | 05:30 AM
Kato's Avatar
Kato
A little toe in in the rear will help traction and stability. Tire wear on the inside will increase. Stock Z settings seem pretty good...I would try to dial out some understeer...I would start off with adding a bit more negative camber in the front. Track it, see how your car behaves...adjust your alignment from there according to how you want your car to handle.
Old Jul 28, 2005 | 08:09 AM
Kato's Avatar
Kato
Sorry, I mean toe in will cause more wear on the outside of the tire, not the inside.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
