Will LE37T 19x10.5 +38 offset clear brembos and inside of strut in rear?
Old Aug 3, 2005 | 11:17 PM
maximapowr's Avatar
maximapowr
Default Will LE37T 19x10.5 +38 offset clear brembos and inside of strut in rear?
I've noticed the volk offers the le37t in 19x10.5 with a +38 offset. I know the standard fitment for the z is the +22 offset, but this is know to rub with a 285/35/19. The +38 offset would seem to be the best solution. You might not get so much concavity of the spokes but at least it won't rub. Since the wheel will sit further in though, it may hit the brembos on the track or touch the rear strut? Do any of you know if this will fit? I've never seen anybody on this board with this setup...
Old Aug 4, 2005 | 12:47 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
you will be very close on the inside... as long as you get the mid pad / high pad version they should clear...
i have 295/35/18 on a 10.5 +30mm wheel and i have a good 15mm clearance at full slam on the inner strut...
hulkout
Apr 28, 2017 09:00 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
