suspension advice
Old Aug 24, 2005 | 10:56 PM
r26's Avatar
r26
Default suspension advice
I want to upgrade my suspension. Price is somewhat an issue. Don't want to spend over $1,500. I want the best balance between performance, looks, and comfort(don't want to get headaches while hitting bumps) What suspension setup would you choose. I am considering tein flex, cuscos, or tanabe. I'm also considering eibachs with koni shocks (if cheaper and performs good). Would there be something missing with the eibach set as compared to a full suspension set.
Old Aug 24, 2005 | 11:42 PM
350z bra's Avatar
350z bra
tein flex gots my vote
Old Aug 24, 2005 | 11:56 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Tein flex if u want a smooth ride. Full coilover will allow you to corner balance the car
Old Aug 25, 2005 | 08:32 AM
Gsedan35's Avatar
Gsedan35
Your really pondering jumping into two different swimming pools. A shock/spring combo or coilovers.
The biggest problem is, you'll be too tempted to pick a shock/spring system based on drop amount vs picking the best possible spring to compeat with a coilover setup. Being progressive, the Eibachs will not have the at the limit feel that a linear spring system will offer. I would go with the Tokico D-spec setup with 1.2" drop springs, you'll get double adjustable shocks and linear springs with decent spring rates.
Eibach 350Z progressive springs
Spring rates in LBS notice the rate spreads
296/384 front 316/421 rear
F +22% R +23% (looking at peak rates only vs 03/04 cars)
Spring stiffness to oem as seen in a right hand corner because of the progressive spring rates, on a linear spring system, like the oem setup use’s, you would NOT see a difference left to right. (reverse for a left hand corner)
RF-6%
RR -8%
LF +22%
LR +23%
Tokico D-spec shock combo with 1.2" Tokico 350Z drop springs
Spring rates in LBS
375/375
Stiffer then oem by F +20% R +10% (vs 03/04)
For coilovers, HKS RS, $1600 or less when on sale. PM Adam at Z1 performance and talk to him about them. Quiz him about the Cusco Zero 2's he removed in favor of the HKS RS coilovers he's now running. I could see Cusco Zero 2's if Cusco can be contacted and they ok the use of 9Kg front springs, though speaking to them might not be possible since they have no U.S office. For sure do NOT go with the Pillowball version. Here's a direct link to pm Adam https://my350z.com/forum/private.php...m&userid=11322
On the Tein flex, I urge caution. Run a search. While they have many very good reviews, they have many bad review's concerning the harshness of running spring rates that are 114% stiffer then oem, even at the lowest dampning settings. I would only consider them after you have riden in a Z that has them and you get to drive over not so smooth pavement, I'm sure you can easily get such a ride if you simply ask. Myself I would only consider the Flex if I were to run them with softer 560lbs springs, which would add $260 cost.
Here's one of the flex review's that is not flattering.
Originally Posted by KShep
Just switched from the Tien Flex w/edfc to the ZEAL Function V-6. Street use on 35 series rubber.
My Driving Impressions
After driving with the Tien Flex, set to full soft for 5K miles I was fed up with the stiffness of the ride. Every crack and expansion joint in the pavement was transmitted into the cabin with varying degrees of bumps, thumps and clunks. Over bridges or uneven pavement I might as well have been on an amusement park ride...very bouncy.
The ZEAL's are set on the softest rebound setting (01). First off, I still feel very connected to the road and the Z is as sure-footed as ever. Small variations in the road surface are still communicated to the driver, but just enough to subtley convey the information as opposed to ramming it into your skull. NO more bouncy ride over bridges or uneven freeways. IMO, the ZEAL's are a viable option and improvement vs OEM for anyone wanting to lower thier Z and have an adjustable rebound/compression rate. We are very close to spec camber and toe on the rear of the car with no other modifications other than the Hotchkis sways.
Thank you again illz33 for posting your review.
Also thanks to Adam at Z1 Performance for faciliating shipment of these coilovers so they could be installed in time. Dependable, reputable online vendor.
http://z1auto.com/prodmore.asp?model...ng&prodid=1293
Sorry I don't track the car so no review available there. illz33 is on vacation and does track his Z...from what I have read of his initail impressions he is very pleased with the setup at the 5th adjustment level. Looking forward to hearing a more detailed review from him.
Another one
Originally Posted by nbp78415
road in RashMan's G last night. on the softest setting the flex's are still pretty harsh. i wouldnt mind but im sure passangers that arent performance oriented would get pretty damn irritated. on the stiffest setting. whoaa.. i felt like a damn bobblehead. haha.. for performance, i can sure as hell say that it road nice. but on a daily driver... i dont know bout that! haha
Old Aug 25, 2005 | 08:47 AM
MIAPLAYA's Avatar
MIAPLAYA
Having ridden on B&G springs and Hotchkis springs followed by some ride on HKS coilovers I have to say coilovers are the way to go for sure. You may pay a little more then you want to initially however it will last you forever and is WAY more functional then any spring and shock set you could get. The HKS coilover I rode on were HKS LS+ on a G. The owner protocav ordered a different set of springs to make the spring rates essentially identical to the HKS RS (before the RS setup was out). This has by far been the nices set I have ever felt.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
