Recomendations on pads rotors for Track Brembos?
Old Sep 11, 2005 | 02:58 PM
RA11325's Avatar
RA11325
Default Recomendations on pads rotors for Track Brembos?
I would like to start tracking my Z soon, and was wondering if anyone could offer some recomendations for pads and rotors for the Track brakes? Maybe a lighter rotor since the stock ones are heavy as hell.
Old Sep 11, 2005 | 04:08 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
The best way to go would be the 2 piece stop tech aero rotors... They are expensive at first, but when you go to change rotors again you pay alot less since you only replace the outer friction ring. They are a little lighter then the stock...
http://performancenissanparts.com/ca...2+350z&x=0&y=0
Old Sep 11, 2005 | 04:17 PM
John's Avatar
John
Can't go wrong with the Stoptech 2-piece rotors. If you want an affordable OEM Brembo replacement, Racebrakes.com and Cobalt both have very affordable OEM replacements.
As for your pads, it really depends on how much track experience you have.
Old Sep 11, 2005 | 04:18 PM
Enzo Driver's Avatar
Enzo Driver
Holy over-heated caliper.
I had Hawk HP+ pads on my Brembo's, and they were great for tracking.
But do you know how much light the rotors are?
Old Sep 11, 2005 | 04:21 PM
Jason@Performance
Performance Nissan
Yeah thats our race car's caliper...
Old Sep 11, 2005 | 04:23 PM
John's Avatar
John
HP+ pads are a good option for less-experienced drivers at the track, Cobalt GTS and Carbotech Panther Plus are better options if you're going to swap out your pads.
The Stoptech rotors are 2lbs lighter in the front and 2.5lbs lighter in the rear.
There are lots of us on here who have "customized" calipers.
Old Sep 11, 2005 | 05:27 PM
Enzo Driver
I had the "customized" caliper on my old Z, but thankfully my new one has't been abused too much yet.
I was under the impressin that the rotors were much lighter than that. Are there any lighter ones?
Old Sep 12, 2005 | 07:06 AM
thawk408's Avatar
thawk408
John, what would you recommend as a track only pad that is rotor freindly. And on the track I do push my car to the best of my ability, which I would like to think of as fast. I was thinking maybe Performance Friction 01 front and back, but I didn't know if that might be to much.
Old Sep 12, 2005 | 01:39 PM
John's Avatar
John
PFCs are great from what I hear, but they're expensive. I've used Cobalt VRs in the past, and loved them. I've also tried Carbotech XP10s, but prefer the VRs more. I'm going to be ordering a set of PFC01s next for ***** and giggles. PFCs for the rear would be overkill IMO.
Old Sep 12, 2005 | 02:16 PM
EnthuZ's Avatar
EnthuZ
I've had good results with Carbotech XP-10 front & their Panther + in the rear. (OK, I run Stoptech 13.1" Front kit).
Am I the only one with Stoptech special order rotors with purple hats?
BTW, my aluminum lug nuts once upon a time were black anodized!
Attached Thumbnails Recomendations on pads rotors for Track Brembos?-rear-brembo-s-8-16-05-1.jpg   Recomendations on pads rotors for Track Brembos?-rear-brembo-s-8-16-05-4.jpg
Old Sep 12, 2005 | 02:37 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
How much and where can you purchase just the outer friction ring on the stoptech? I was about to purchase some cheap rotors, but if the friction ring is considerably cheaper, I'll get the stoptechs instead.
Old Sep 12, 2005 | 02:40 PM
Jason@Performance
Performance Nissan
here you go...
http://performancenissanparts.com/ca...ech+aerorotor+
It will be around those prices... but PM me and I can see what I can do...
Old Sep 13, 2005 | 05:24 AM
sdoow's Avatar
sdoow
We also offer two-piece rotors for you:
http://www.racingbrake.com/NISSAN_s/521.htm
And we reccommend using Hawk pads with our rotors. The rotors are center-mount design to give you better air flow, and convergent vanes to keep the rotor at a cooler temperature.
Old Sep 13, 2005 | 08:33 AM
RA11325's Avatar
RA11325
thanks for the advice guys!
Old Sep 13, 2005 | 12:34 PM
protocav's Avatar
protocav
what is the hat made out of on your two piece rotors? aluminum, steel?
Old Sep 13, 2005 | 01:03 PM
sdoow's Avatar
sdoow
Aluminum.
Old Sep 13, 2005 | 01:09 PM
sentry65's Avatar
sentry65
the burninator
how much do they weigh in comparison to stock brembo rotors?
also can you buy just the outer rotor and keep the center?
are you planning on doing rear rotors?
Old Sep 13, 2005 | 06:43 PM
Enzo Driver
Sounds like they are pretty nice. How much do they weigh in comparison to the stock rotors, or even to the Stoptech's? I am really lookin for the lightest rotors.
Old Sep 14, 2005 | 05:18 PM
J Ritt's Avatar
J Ritt
Correct me if I'm wrong, but I don't believe the Racing Brake rotors are actually floating.
Here's the difference between the two:
http://8.7.96.35/tech_info/faq_rotorsystems.shtml
With a fixed hat rotor, you aren't gaining any of the benefits of the floating rotor system, other than a bit of a weight savings. You still have issues like coning and tapered pad wear. Here's the press release for our AeroRotors for the Z:
http://www.stoptech.com/press_releas...drkrelease.htm
Our replacement iron for these rotors is very reasonable. So, after you go through your first set on the track, the next set will be $130 for each front (including new attachment hardware), and $108 for each rear (with hardware).
Old Sep 14, 2005 | 09:25 PM
Jason@Performance
Performance Nissan
A+++++++++++
Fix the press release link though!
