2006 brembo surprise :)
Old Oct 18, 2005 | 08:08 PM
undRgrNd350z's Avatar
undRgrNd350z
Default 2006 brembo surprise :)
this beautiful pair of drilled rotors arrived at my door today...
and the braided lines.....
+ the nismO sticker....
let me know what you think.
Attached Thumbnails 2006 brembo surprise :)-forum.jpg   2006 brembo surprise :)-forum2.jpg   2006 brembo surprise :)-forum3.jpg   2006 brembo surprise :)-forum5.jpg   2006 brembo surprise :)-brembosforum.jpg
Old Oct 18, 2005 | 08:10 PM
undRgrNd350z
Attached Thumbnails 2006 brembo surprise :)-forum4.jpg   2006 brembo surprise :)-nismo.jpg
Old Oct 19, 2005 | 04:51 AM
gringott's Avatar
gringott
Very Large NISMO. I like it has the filled O rather than the latest regualr O.
Old Oct 19, 2005 | 08:17 AM
Joeys_z's Avatar
Joeys_z
HOLY NISMO BATMAN!!!! That thing is way to big.....I think it really looks terrible!!
Old Oct 19, 2005 | 08:26 AM
03znj's Avatar
03znj
Know it all
What is that thing behind the wheel?
Old Oct 19, 2005 | 08:40 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Thumbs down
Originally Posted by mc350z
thats one big *** nismo sticker
Bigger than the Team Kawasaki on the truck behind the Z!
Old Oct 19, 2005 | 08:42 AM
Zexy's Avatar
Zexy
What's up with that Nismo Humungo decal?
Old Oct 19, 2005 | 08:47 AM
sen_jen's Avatar
sen_jen
nice sticky. something of that magnitude tells us your Z is monsters under the hood, and you're almost sponsored by NISMO with everything on your Z being NISMO! good deals with the Brembo's, and the sticky mang!
Old Oct 19, 2005 | 10:11 AM
Major's Avatar
Major
Default Brembo Rotors
undRgrNd350z,
Why Brembo? Good Price?
The rotors look good, should really enhance the appearance!
I want to upgrade my rotors as well, I would like the StopTech 2-Piece Aero, but the price is killing me.
Thanks
Major
Old Oct 19, 2005 | 12:59 PM
undRgrNd350z
the sticker is big. haha. and the 06 is bigger. haha. j/k.
Old Oct 19, 2005 | 07:19 PM
Zivman's Avatar
Zivman
From my experience:
crossed drilled = bad news
Just keep your fingers crossed that they don't crack
Old Oct 19, 2005 | 08:12 PM
Kolia's Avatar
Kolia
Originally Posted by Zivman
From my experience:
Forget about crossing your fingers. Mark every day they haven't cracket yet on the calander . Be happy if your get to 90...
Old Oct 22, 2005 | 05:43 AM
Nano's Avatar
Nano
we have had brembo drilled rotors on our porsche for 4-5 years without them cracking ever. That's 1500 days
If you don't use race compounds they will never crack
Old Oct 22, 2005 | 07:15 AM
Kolia's Avatar
Kolia
And how much did these cost again?
What would be the point of getting drilled disc you can't push hard?
The holes sees concentrations of constraint when heated. When the disc cracks, it will be around the holes.
The disc won't explode suddenly. It will last not last as long as a plain one, that's all.
Old Oct 22, 2005 | 10:14 AM
zweetredline's Avatar
zweetredline
"it's the size of texas, mr. president"
Old Oct 22, 2005 | 10:26 AM
Zivman's Avatar
Zivman
I doubt the brembos in this thread are equivalent to those you are getting on a porsche . Besides, putting out a word like "never" is a bit much. True, they might not crack, but I have yet know a person running any crossed drilled rotor that didn't crack. Race compounds most likely only play a small roll in why they crack. Drilling severly weekens the integrity of the rotor. Do some heavy braking, not even on the track, and the heat and stress take their toll on them.
more power to you if you can get by running them without issue. You won't see them on my car.
Old Oct 22, 2005 | 04:24 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
oh lord......here we go again
do you happen to notice how many cars run drilled rotors stock? And no, those holes are not "cast" into the rotors...they are drilled after the fact.
The trick with ANY rotor...drilled, slotted, solid..makes no difference, is running a pad that is well matched to the rotor. Anyone that says otherwise either has a commercial agenda they are pushing or do not have the knowledge required to make the case otherwise. I've run drilled rotors on so many of my own cars I cannot even count. I've also NEVER had an issue with them whatsoever. I've run slotted rotors as well..and again, never ran into a single issue. Different brand rotors, different cars, same result...match your pad to your rotor and you'll be ok. Now, how do you know what pad to run? Unfortunatley, it is alot of trial and error I find....there is no other way
I swear the amount of misinformation that gets tossed around on this board in particular is mind boggling
From the horses (Brembo's) mouth:
What are the advantages of drilled and slotted discs?
The main advantages of drilled and slotted discs are the same: increased brake "bite", and a continuous refreshing of the brake pad surface. Drilled discs have the additional advantage of being lighter and running cooler. However, there are certain pad materials that should not be used with a drilled disc.
Why are there so many holes in a cross-drilled disc?
The number of holes in a cross-drilled disc is part of the engineered system. Brembo has done extensive testing with regards to the number of holes, their size, their location and their chamfering. This attention to detail is what truly sets Brembo apart in the world of braking. The same attention to detail that is delivered to the Ferrari Formula One effort is a component of the high performance program. The number of holes in a disc is in part a function of the size of the disc and the internal venting (if it is a vented disc).
Does Brembo manufacture OEM cross drilled discs?
For some OEM applications, Brembo designs and manufactures cross drilled brake discs to be fitted as original equipment by a vehicle manufacturer. In these instances, the vehicle in question is usually of very high performance and needs the additional performance that these discs offer. The Sport discs that Brembo offers are direct replacements for the discs fitted as original equipment. These discs are available in both drilled and slotted configurations, and are engineered and manufactured to the same high standards as those fitted as original equipment.
Old Oct 22, 2005 | 04:42 PM
Kolia's Avatar
Kolia
Just so you know, F1 discs are plain. Regulations prevents drilling or slotting...
I really don't understand why they would talk about their F1 experience with drilled discs. Doesn't make sense.
This happened with OEM Subaru brake pads. Probably too abrasive for a DBA Gold rotor on a 165hp car...
Old Oct 22, 2005 | 04:51 PM
Z1 Performance
Former Sponsor
the quote does not say they use x drilled rotors in F1....maybe you did not read it carefully. It says they use the same attention to detail in their street disks (drilled and slotted) as they do in the disks they make for F1...is that more clear?
As for your picture...why did that happen? Neither I, nor anyone else can answer that...shall I post the pictures of the drilled Brembo rotors I run on one of my other cars, which have 30k miles on them and not a crack in site, using Hawk HP+?
Proper brake in, and proper pad selection is the key
