Is the Nismo sways option worth it?
So I only plan on getting one option when I order my Z next month---the Nismo S-tune sway bars ($500). For those that have them or have ridden in a car that is equipped with them: Are they worth the money and should I get them?
It's either going to be the sways or the Nismo Cams. What do you guys think?
I've been using the Nismo S-tune sways on my track model for almost two years. The increase in roll stiffness is notable and make the Z much sharper in quick transitions and overall handling. IMHO- if you have to choose between cams, springs, shocks and sways, the sways will have the biggest impact in day-to-day driving with the Z.
Good thread Mr Drifter. I was also thinking of installing these on my Z. Would the dealer be the best place for installing, and does the alignment have to be redone, anybody know?
By the way. I don’t understand why they are referred to as sway bars by Nismo and others.
These bars reduce a car’s tendency, along its longitudinal axis, to roll. These front and rear bars are actually “anti roll bars’. That’s what they should be called.
Swaying occurs on the vertical axis back and forth laterally. Anti roll bars have no effect in that area.
MJD
MJD
MJD
MJD
As soon as you come out with a product for a car and call it an "anti-roll bar" people will be asking "Hlp plz is that the same thing as a sway bar?!!eleven!"
How hard is it to replace the bars at home? I'm not a beginner but definatly no expert. And will I need anything other than simple hand tools? Or should I have a local shop do it? I really want to do this, but just need to know a bit of info.
It is possible to do the job at home. But I found that even with air tools, it took some time and effort. You'll need to put the car up on jack stands and I found the front bar was the toughest. Nissan really torqued some of the front SB mounting bolts and I needed a long breaker bar and a friend to break them loose. The rear wasn't too difficult- you do need to twist and thread the OEM bar to get it out. Just remember which way you did it to get the Nismo bar back in! I'm sure if you do a search on this you'll find some other hints.
Probably took me between 6-8 hrs to do the whole job but that includes jacking the car up and down and removing and installing the wheels. NISMO instructions where not very detailed but I found a few websites that helped. If I can locate them I will post here. Good Luck!
Z ya!
