DA Koni or Bilstein Shocks?
Old Nov 5, 2005 | 10:44 AM
Silverton's Avatar
Silverton
Default DA Koni or Bilstein Shocks?
Are DA (double adjustable) Koni or Bilstein shocks available for the 350Z yet? I know that Truechoice/Unitech were offering a Koni DA setup for the Z, but problems were reported on this forum. Is anyone still running them?
Old Nov 5, 2005 | 01:37 PM
palepony's Avatar
palepony
Silverton
TCKline offers DA koni dampers
http://www.tcklineracing.com/nonbmw.htm
pp
Old Nov 5, 2005 | 04:48 PM
Silverton's Avatar
Silverton
Anyone using these?
Old Nov 6, 2005 | 06:06 AM
Gsedan35's Avatar
Gsedan35
Originally Posted by Silverton
Anyone using these?
Look at the last few posts in the following thread, expecially the very last one.
https://my350z.com/forum/showthread....hlight=tckline
Old Nov 6, 2005 | 06:15 AM
Gsedan35's Avatar
Gsedan35
As mentioned, you do have TcKline DA Koni's. I will point out the fact they they are made by Koni for TcKline, that they do not buy off the shelf SA Koni's and convert them to DA's, they come from Koni as DA's built to TcKline's valving specs. Also the TcKline shocks adjust for compression and rebound seperately, not together. I am seriously considering getting them, I'm simply not thrilled with the SA's dampning on the 448lbs rates I've been running.
Bilstein does not offer a DA shock for the platform, let along a adjustable shock period. Their current H.D. shock should NOT be run with stiffer springs as the shocks do not have a valving range to cover spring rates any higher then oem. Though, you can buy a set of the shocks and have them revalved by Bilstein for cheap, try $65 per shock. But, you'd be rolling the dice on settings since you'd have to nail them, remember the shocks are not adjustable and your left will little room for error.
Old Nov 6, 2005 | 04:46 PM
Silverton's Avatar
Silverton
Thanks for the link: that thread must've snuck passed my radar. So it looks like the TCKline Koni DA's are one option. Are the Truchoice/Unitech Koni DA coil-overs also a good choice?
Old Nov 6, 2005 | 06:48 PM
thawk408's Avatar
thawk408
The Truchoise/Unitech looked to be the best option, but all I have heard about them is problems. I have read that they have had a lot of issues with leaking and the suspension is very loud and annoying. I would advice the TCKline Koni as the best option right now.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Nihsnek
Feb 9, 2016 12:57 AM
Bodyboarder81
Nov 2, 2015 12:17 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Suffolk350z
Sep 13, 2015 02:43 PM
