Spring Rate Database?
Old Dec 29, 2005 | 06:44 AM
cupcar's Avatar
cupcar
I like Gsedan35 he has good answers and good questions!!!!
Old Jan 1, 2006 | 11:44 PM
gringott's Avatar
gringott
Gsedan35 what's the verdict on the Espielr Active GT?
Old Jan 2, 2006 | 04:18 AM
DM4's Avatar
DM4
Gsedan35,
On the 2004.5/2005, if those measurements are on the springs I provided you may want to note that they were from a roadster,
Old Jan 2, 2006 | 05:55 AM
DomZ's Avatar
DomZ
So am I right to say some of these springs with progressive rates listed only have the peak characteristics posted? So would it be safe to go with a linear setup if you want true numbers?
Old Jan 9, 2006 | 05:12 AM
ugylymofo's Avatar
ugylymofo
would it be possible to use the T2 nismo springs with Tokico D2 dampers? What counter reccemendations are there?? Is the spring rate too high to handle the springs? Is there a way to get them custom valved?
I'm trying to find a decent track spring, but beside the nismo T2 springs, there is nothing, everything is progressive/street oriented and either too soft or too high, barely better than stock revised suspension. Why isn't there anything linear in the 500 range with a 1" drop??????
Old Jan 9, 2006 | 05:22 PM
BlackSpec02's Avatar
BlackSpec02
because no one makes struts that can handle that high of a spring rate... and if they did and you bought both then you might as well buy some coilovers... thats my recommendation.... buy coilovers... the tein basics are affordable and have 504 spring rate and you can drop as much or as little as you want.
Old Jan 10, 2006 | 05:26 AM
C Ray Z's Avatar
C Ray Z
I run T2 with S/A Koni's Spotrs and they are fine just have to run at full stiff or near that. There is also a T2 racer who ran last year with S/A Konis.
Just wanted to add to te discussion.
Old Jan 11, 2006 | 03:35 AM
jmark's Avatar
jmark
Anybody know if Koni is going to produce a Koni 1020 Sport Spring Kits for the 350Z?
Old Mar 13, 2006 | 01:40 PM
ASTIG_Z's Avatar
ASTIG_Z
subscribing. Dont know if i want the H&R or Eibach springs for a 2005 Z with 19" wheels. I want a 2 finger wheel gap. any suggestions?
Old Mar 13, 2006 | 03:25 PM
fahrenheit350's Avatar
fahrenheit350
RSR down or Ti2000 will suite you. .6" drop all around and closest spring rates for 04.5 and up.
Old Jan 28, 2008 | 11:30 AM
iStan's Avatar
iStan
ZR
Bumping because I just spent 20 minutes trying to reinvent the wheel created by gsedan35. Thanks for the Info!
Old Jan 28, 2008 | 12:06 PM
Q45tech's Avatar
Q45tech
I measured the FRONT lower arm length @14" and the spring closest point [length along arm from frame] @11" this results in a spring to wheel correction of 0.61 so a spring speced at 300 pounds per inch would really expert 300 x 0.61= 183 pounds per wheel inch. If you jacked up the wheel by 1" it would require 183 more pounds than static...........discounting sway bars this means the front roll rate stiffness is ~~183 lbs per inch.
So a 20% stiffer spring only truely increases FRONT roll stiffness by 20 x 0.61 or 12.2%.
Worse add in the sway bar and a 20% stiffer spring may only add 1/2 -3/4 so 6-9%.
Old Jan 30, 2008 | 09:48 AM
Gsedan35's Avatar
Gsedan35
"The motion rates (as I measured and averaged them over full travel) are.... .688 F and .649 R (measured at center of spring)"
Originally Posted by hippie
In response to some posting above here are some numbers that I measured with my Z.
The front end gains 1deg of camber per in. of bump....... .8 lower equals .8 deg more neg camber.......LS-1.8 RS-2 based on average static numbers
More camber will produce toe in, BUT lowering the car will produce toe out....about 1/32 out per side per in. of drop.....up to 1/16 out per in. per side with more travel. The rear gains toe in with bump....starts at 1/16 per in. and goes to 3/32.
theses rates with #690 springs equal at the wheel....326.6F 290.6R
stock revised...........146.3F 189.9R
The one thing that is easy to miss is that the Z relies on the front bump stops for spring rate. It is common for manufacturers to use soft springs for ride comfort along with a progressive bump stop that engages early to control big susp. movement. I haven't rated mine YET.
John, Your guestimates are close to what I figured when I did natural frequency calculations for my car. F w/850=2.3Hz Rw/600=2.1Hz
In reality the rear is too stiff (read SCARY) for a typical auto-x lot. It would proably be close for road course use.
mike
Old Mar 9, 2008 | 05:47 PM
zBear's Avatar
zBear
Been looking for this for awhile. Great info!
Old Jul 26, 2008 | 04:49 PM
laze1's Avatar
laze1
Default are stock springs Linear?
Oem springs 350Z’s 2003/2004
Front:314 Rear:342
Oem springs 350Z 2004.5/2005 (found 04 car's that have the revised susp.)
Front:314 Rear:427
Old Jul 27, 2008 | 06:18 AM
Gsedan35's Avatar
Gsedan35
Front:314 Rear:342
Front:314 Rear:427
Front springs are tapered, fatter at the top where they narrow towards the bottom. This technically makes them slightly progressive, as would any spring in the front that uses the oem upper mount diameter and also uses the lower shock seat (stamped steel or add on's like Koni or Bilstein lower front spring seats). Exception is Bilstein Pss9, it uses the oem upper shock mount in the front, but uses a aluminum adaptor at the top on a linear spring.
So, yes the oem front springs are slightly progressive, but the min and max rates are too close to have any meaningfull impact on any type of performance driving, be it street or track. And most important of all, NO COIL BINDING occurs anywhere in travel as to suddenly change spring rate.
Old Jul 29, 2008 | 08:21 AM
Q45tech's Avatar
Q45tech
Calculating is great but actually measuring the roll stiffness is better in that you get everything from tire to body flex included in number.
Tires actually lower stiffness rate [2 springs in series] by 5-9% depending on design and inflation. Add in the wheel, the hub, the spring seats and any rubber and the stiff springs become 7-18% softer after correcting for motion ratio.
Old Aug 5, 2008 | 10:42 AM
  #38
LAKERSFAN's Avatar
LAKERSFAN
anyone know the spring rates on the Eibach sportline springs? i see specs on the pro kit but not the sport line ones...........
I am on the Nismo S-Tune Suspension and would like a more aggressive drop so i was thinking of swapping out the Nismo springs for the Eibachs but keeping the Nismo shocks? Would this be a bad idea?
only thing i can tell so far are both springs are progressive.......
any input would be much appreciated.
thanks
Old Aug 5, 2008 | 11:31 AM
  #39
LAKERSFAN's Avatar
LAKERSFAN
bump
Old Aug 6, 2008 | 07:47 AM
  #40
Gsedan35's Avatar
Gsedan35
thanks
Not to bust your chops but if you would have run a search on "sportline" and narrowed the search to my username you would have seen where I posted the sportline specs just a few threads down.
So,...
This is what you have now.
Nismo S-tune (twin tube construction, uses progressive springs)
350Z .8"/.8" drop
Spring rates 448/504
This is what you thinking about swapping onto the Nismo shocks.
Eibach 350Z sportline progressive springs 1.2"/1.2"
F: 239/400 R: 257/435
Should work, peak rates are within 50 and 70 pounds. That and the change to a wide rate spread in the front means the change will not be a plus on the performance side since the front Nismo springs are only mildly progressive. Also, I don't like seeing people go lower on less spring rate since the oem bumpstops are rather unforgiving. I would take the simple measure of finding a shop that know's how to measure travel and can install different bumpstops. Or you could just roll the dice like everyone else does.
