Arizona Z Car BBK
Old Nov 28, 2005 | 01:04 AM
BlackSpec02's Avatar
BlackSpec02
Default Arizona Z Car BBK
http://www.arizonazcar.com/350zbrakes.html
Does anyone have this kit, or any experience with it?
Looks like a good kit at an amazing price.
Old Nov 28, 2005 | 04:59 AM
Mike Wazowski's Avatar
Mike Wazowski
I actually went out and met the guy who makes these. He has them on his daily driver, they work awesome. The downfall is you will lose your parking break with the rear kit. If you just plan on doing a front BBK, this rocks
Old Nov 28, 2005 | 08:33 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
why is that? are they only happen with this kit or will all BBK?
Old Nov 28, 2005 | 08:39 AM
atlsupdawg#2's Avatar
atlsupdawg#2
They don't use rotor hats on the rears that accomodate the parking brake. Instead they use a line lock which isn't all that bad either..
Old Nov 28, 2005 | 01:32 PM
BlackSpec02
You still have a parking brake right? It is just now connected to the rear discs instead of the drum?? or?
Old Nov 29, 2005 | 10:37 AM
atlsupdawg#2
Yeah Black, it's just a hydraulic line lock for the rear discs. You just depress and hold the brake pedal then close the line lock vlave. A lot guys put them on their front brakes so they can do burn outs without smoking the rears.
Old Nov 29, 2005 | 05:28 PM
BlackSpec02
oh okay... with this though you couldn't pull the e-brake to use for drifting and things like that anymore though?
So it is probably preferred to have a brake kit that retains the factory e-brake?
Old Nov 29, 2005 | 09:48 PM
350Zteve's Avatar
350Zteve
The Wilwood BBK has been out for some time. Do a search and you will find more threads on this. I believe Sharif@Forged has them, at least on the front.
I don't see how a line lock would work since it requires power to lock the pressure.
Old Dec 6, 2005 | 10:53 AM
kbiz's Avatar
kbiz
I think it works best to set the line lock while your car's still running, then shut it off. I've seen this before in street rods and it didn't seem to be all that sturdy... hills wouldn't be that safe. Plus if you leave if for a while the car can slowly roll, if it's not in gear.
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
