350evo sway install question
Old Feb 3, 2006 | 09:29 PM
accordfreak's Avatar
accordfreak
Default 350evo sway install question
i read all the install threads but i have one question that i couldn't find an answer to.
I flipped the front end links so the longer bolt will be bolted on to the sway. My question is do you keep the washer? It seems like there are 2 threads left on the nut when I tightened it with the washer. I feel that it could be a bit unsafe. Did you guys leave it on or off?
thanks
Old Feb 4, 2006 | 07:34 AM
xziteme's Avatar
xziteme
When they installed my 350EVO sways, they had to grind off some of the metal at the end of the sways so that more threads show through when you tighten up the nut w/ the washer.
Old Feb 4, 2006 | 09:02 AM
C Ray Z's Avatar
C Ray Z
Default Read the instructions
There is a suttle change required. You need to remove the connecting link and flip it upside down. The link looks symetrical but is not.
Old Feb 4, 2006 | 03:03 PM
1G-350Z's Avatar
1G-350Z
thanks
Where did you get the 350evo sways from... Last time I checked they were back ordered...
Old Feb 4, 2006 | 11:18 PM
accordfreak
I bought it used for 150.
update: I left the washers out. I hope that won't cause any problems unless someone tells me why I should leave them on. the bolts threads to the end of the nut now since the washers are out.
I just test drove it and it feels great but for some reason the steering response seems a little loose? It doesn't feel as tight as before. MAybe my collars are a little too loose?
any comments?
Old Feb 5, 2006 | 04:17 PM
CrazyMike's Avatar
CrazyMike
any comments?
What setting did you use in front? The softest setting on the 350evos is slightly less stiff than stock. If that's the case, give the middle holes a shot. The collars shouldn't change the feel of the sways too much. They are mainly there to keep the sway centered and keep it from bumping the struts.
Workshop12
Mar 23, 2020 01:45 PM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Paul.
Oct 16, 2015 07:34 PM
RiujinZero
Sep 25, 2015 01:19 PM
