Lubricant for Sway bar?
Old Feb 11, 2006 | 07:16 AM
tractng's Avatar
tractng
Default Lubricant for Sway bar?
Guys,
I am about to intsall the hotchkiss sways for a friend. It is used. What kind of lubricant should I get from the Auto store. I don't mean the other kind of lubricant The lubricant that came with the sway when you bought it new.
Tony
Old Feb 11, 2006 | 03:08 PM
cm-racing's Avatar
cm-racing
Use thick silicone, such as sil-glyde.
Old Feb 11, 2006 | 03:23 PM
CrazyMike's Avatar
CrazyMike
Yep any silicone lube will do. Just make sure it isn't mineral based - that will eat into and deteriorate your bushings. Prothane also makes a silicone lube, I think I bought some tubes of it from summitracing.com a while back...
Go here: http://store.summitracing.com/ and search for PTP-19-1750. Its a 3 tube kit - each tube is about enough for one sway. You might want to consider ordering 2 kits if you plan on doing your sways somewhat frequently.
Old Feb 11, 2006 | 03:38 PM
Yama1's Avatar
Yama1
If the busings in the kit are urethane you need to use a specific moly-lube for urethane bushings only , this can be purchased from your local speed shop, we use it a lot in the off-road industry, it's made by energy suspension, daystar and prothane.
Old Feb 11, 2006 | 05:49 PM
Mr.Jadkowski's Avatar
Mr.Jadkowski
I thought the hotchkis kit came with lubricant?
Old Feb 12, 2006 | 07:44 AM
cm-racing's Avatar
cm-racing
The energy suspension lube is just a teflon based lube which can also be purchased anywhere.
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
