Big brake problem
Old Feb 13, 2006 | 12:39 AM
evobunny's Avatar
evobunny
Default Big brake problem
sup guy was just wondering if anyone incounter any problem after installing a big brake kit. any problem at all. Just wondering what im getting myself in to. Any advance you can give me would help. So I dont make a mistake.
Old Feb 13, 2006 | 10:19 AM
Chebosto's Avatar
Chebosto
front BBK,
if you want to remove the brake dust cover, you can remove the wheel hub from the suspension arm and the brake dust cover will come off quite easily and no need to cut.
for the rear bbk, first bend back the dust cover and using a mallet and a chisle to seperate the spot welds attaching the dust sheild to the hub.. you *can* remove the rear hub but you have to take off the drift shafts, and its not worth the time.
test fit the brake pads in the caliper. if its a tight fit sand down some of the edges with a dremel tool and you should be golden.
use Box wrenches when removing bleeder valves and the brake lines.
Old Feb 13, 2006 | 10:42 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
The answer is NO. The next question for you is: are you going to track your car or just daily driving?
My suggestion:
* Tracking: Stoptech
* Daily Drive: Rotora
Contact Marty at Injectperformance for best price. I bought mine from them. Love it.
Uriyo_
Sep 8, 2021 08:46 AM
