springs for 06
Old Feb 27, 2006 | 06:16 AM
eez's Avatar
eez
Default springs for 06
I am getting the itch to lower my car. This will be the first car I have ever lowered, so I am hesitant to go very low. Also, since this is my first time I do not want to go all out, something cheap - I can always upgrade in the future.
After doing some research I have found the following possibilities:
1. Tein Basic Coilovers $800
pros: adjustable to around 25mm
cons: more than I want to spend.
2. Hotchkis Springs $150
pros: 15mm front and 19mm rear. Linear spring
cons: spring rates are very low compared to the 2006 stock (314/427). I have been told that this spring was designed with the OEM in mind, but that would only be true for 03-04.
3. RS*R $220
pros: springs rates are very close to stock 345/417 – transfers stiffness to the front (not sure if this is good or not). Linear spring
cons: 15mm front and rear – I would really like to get as close to 25mm as possible and still be in factory alignment specs (20mm would be good)
Is there a spring out there that offers a 20mm drop front and rear with similar rates to the 06 stock? I have not been able to find one. I think based on my requirements the Nismo S-Tune suspension is the best fit, but I can’t justify spending $1400 on suspension due to the other modifications I want to do – wheels, mrev, and exhaust.
Any thoughts, suggestions, or comments for direction/decision would be much appreciated.
Thanks
Old Feb 27, 2006 | 06:10 PM
fishanan's Avatar
fishanan
You may check Tein S-Tech. Many people like it.
Old Feb 27, 2006 | 08:15 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Hotchkis are definitely best bang for your buck spring-wise...
The rates are very much acceptable. The drop is minimal. Any less drop (tein h-tech spring) and you won't even know the difference.
Old Feb 28, 2006 | 01:15 PM
jcarp's Avatar
jcarp
I Got Tein And Love Them If You Had The Extra Money I'd Do The Coil Overs
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
