There may be hope for Castor Adjustment
Old Feb 28, 2006 | 03:35 AM
MR RIZK's Avatar
MR RIZK
Default There may be hope for Castor Adjustment
Check out this nismo Z at TAS 2006. Look at how much caster is running on the front. Only if we knew how it was done !
Old Feb 28, 2006 | 05:06 AM
21112's Avatar
21112
This may be the answer:
If you can read japanese:
http://www.nagisa-auto.com/products/z33_arm.html
If you can't:
http://performancenissanparts.com/ca...oducts_id=6563
Attached Thumbnails There may be hope for Castor Adjustment-z33_f_pillow_tension_rod.jpg
Old Feb 28, 2006 | 09:39 AM
konspec's Avatar
konspec
ouch that's some ching for caster adj. I wonder how benefical this could be?
Old Feb 28, 2006 | 01:44 PM
MR RIZK's Avatar
MR RIZK
Thanks a bundle for that link
Old Feb 28, 2006 | 03:47 PM
EnthuZ's Avatar
EnthuZ
MR RIZK, Would you please explain how you can SEE caster in the photo?
I ordered X-Ray glasses, but, d*mn, they were back-ordered!
Old Feb 28, 2006 | 04:23 PM
MR RIZK's Avatar
MR RIZK
I'm waiting for my glasses too. My other one's broke at the beach from excessive use !!
Look at how the wheel sits in the arch. It would appear quite a bit forward which would mean positive caster.
Old Feb 28, 2006 | 06:38 PM
Gsedan35's Avatar
Gsedan35
Originally Posted by konspec
ouch that's something for caster adj. I wonder how benefical this could be?
Only if it REMOVES caster, oem runs pretty high numbers.
Old Mar 1, 2006 | 12:55 PM
21112's Avatar
21112
Originally Posted by MR RIZK
2112
Anytime.
I saw the product and had no idea what the heck it did. I posted a thread on here, but nobody answered. When I posted on another forum, a friend informed me of how the part gives the ability to change castor (and then told me what the heck castor is
So, just passing whatever information on that I can.
Old Mar 1, 2006 | 02:42 PM
MR RIZK's Avatar
MR RIZK
More caster will give more oversteer.
If anyone is interested check this link
http://www.rallylights.com/other/stuning.htm
Old Mar 1, 2006 | 03:15 PM
EnthuZ's Avatar
EnthuZ
I am curious as to who & why my reply was deleted. I thought it was informative.
Old Mar 1, 2006 | 08:32 PM
MR RIZK's Avatar
MR RIZK
Do you want post your reply again. I'm more than happy to read it
Old Mar 1, 2006 | 09:57 PM
EnthuZ's Avatar
EnthuZ
Maybe I didn't do something correctly.
It looks to me that the entire wheel is moved forward. The Nagisa Auto Adjustable Tension Control Rods shown above will move ONLY the lower ball joint, with the upper ball joint being the pivot point. I couldn't fathom a reason to add a sh*tload more caster into a Z. We already have about 9 degrees of positive caster. To move the wheel that far forward with only moving the lower ball joint, I would guess it has about 20 degrees positive caster! Then again, I never did find an explanation for the 2 lower ball joints......
$1200.00 to adjust caster? I don't think so.
Old Mar 2, 2006 | 04:47 AM
Kolia's Avatar
Kolia
More steering feedback...
Old Mar 2, 2006 | 05:40 AM
njsho's Avatar
njsho
More positive caster should allow you to run less static camber, but I forget the downside.
Old Mar 2, 2006 | 06:29 AM
Kolia's Avatar
Kolia
I'm not sure but we might encounter more bump steer at the same time?
Old Mar 3, 2006 | 09:29 PM
julian's Avatar
julian
bump steer is cause by the arcs of the tie rods not being the same as that of the wheel (control arm). i don't know what effect caster has on that though.
my understanding of caster is it provides more stability at higher speeds. but i think it slows down steering response.
ablaine
Nov 29, 2016 10:13 AM
dcains
South East
20
Feb 22, 2016 10:27 PM
Tochigi_236
Sep 27, 2015 03:40 PM
