camber adjustment with camber arm / toe bolt?
Old Apr 3, 2006 | 12:42 AM
j66's Avatar
j66
Default camber adjustment with camber arm / toe bolt?
i want to fix camber correction for the rear, so i need the camber arm only or do i also need the toe bolt, as the camber adjustment will move the toe?? hope you can let me know soon. thank you!
jackie
Old Apr 3, 2006 | 09:11 AM
wong hun xun's Avatar
wong hun xun
how far are you lowered (or are you?) there are stock adjustment bolts that can usually get you back in spec for mildly lowered cars.
Old Apr 3, 2006 | 09:33 AM
Mike Wazowski's Avatar
Mike Wazowski
if your lowered just do the spc set-up.
Old Apr 3, 2006 | 01:57 PM
j66's Avatar
j66
yes lowered 1.2" front and rear. with kg/mm springs.
another quetsion is the SPC kit don't have the ball bearing joint like the others cheaper brands on ebay. coz the ballbearing help alot? or is just a fansy thing to have?
Old Apr 4, 2006 | 11:53 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the SPC is hands down the best kit for the $$
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
