Rear rotor offset
Old Apr 3, 2006 | 08:50 AM
ZRaven's Avatar
ZRaven
Default Rear rotor offset
Is there an aftermarket rear brake rotor that has a smaller offset than the OEM rotor? I've been researching on the forums & online and it seems the only way to get a custom rotor offset is to do a 2 piece aftermarket.
I have a set of wheels with an aggresive offset and on test fitment, the wheels were sticking out of the fender by ~.5". I want to change the rear rotors so that the hat's aren't as thick (smaller offset). I know that the rear rotor hats are ~1.75" tall, I want a rotor with a hat that is 1" or .75".
Can anyone help, please?
Old Apr 3, 2006 | 09:54 AM
StopTech's Avatar
StopTech
Vendor - Former Vendor
The rear rotor offset is determined by the width of the parking brake setup housed within the rotor hub. The only way to get a reduced offset would be to remove the parking brake and find a rotor that would fit. You would also likely need to get a custom bracket machined to relocate your rear calipers.
