did my coilovers get installed right???
Old Apr 20, 2006 | 04:47 PM
b_nazty's Avatar
b_nazty
Default did my coilovers get installed right???
i was wondering if anyone could help me out with this situation...a friend of mine installed my coilovers for me last weekend and the way he installed the rear spring was with the adjustable pertch on the top of the spring so there is no rubber bushing in between the pertch and the car so it is metal to metal and is really annoying..now what i would like to know is if wether or not that is how it is supposed to be installed or if there is something to put between the two to get rid of all the clanking or does the pertch sit on the bottom with the stock rubber bushing sitting on top of the spring..any advice would help..i bought these used so i didnt get any instructions with them
TIA,
b_nazty
Old Apr 20, 2006 | 04:55 PM
Vamos_Rafael's Avatar
Vamos_Rafael
he did it right because thats the only thing available...
if you find it squeeky then use a layer of rubber matting...
im running the same way ur right now...
Old Apr 20, 2006 | 05:34 PM
1nate7's Avatar
1nate7
I am pretty sure there is supposed to be a rubber piece at both the top and bottom of the rear spring. The bottom rubber piece is removeable and has a "groove" in it that the spring fits into. The top rubber piece is fixed. If you have both rubber pieces on top with nothing on the bottom, that is wrong.
Old Apr 20, 2006 | 05:44 PM
Vamos_Rafael
the coilover height adj seat sits on the bottom...
its metal... if you want to get less squeak, put some dampening material in between because the spring adj seat is just like that
Old Apr 20, 2006 | 05:47 PM
b_nazty's Avatar
b_nazty
does anyone know if the brand new kit comes with a rubber peice to go in between the pertch and the car and if there are brackets that come seperatley for the brake lines because there wasnt any on the front
Old Apr 20, 2006 | 06:00 PM
1nate7's Avatar
1nate7
Sorry for the wrong information in post 3. I guess I am not running a true "coilover" on the rear so it sounds like it was installed correctly.
Old Apr 20, 2006 | 06:02 PM
Vamos_Rafael
u need to custom fabricate brake line holding brackets bro
Old Apr 20, 2006 | 06:04 PM
Vamos_Rafael
no cuz if u run true coilover u wont have spring/adj perch etc etc
so u wont have this problem
u'll just have something similar to the fronts (coilover)
the type we're talking about is basically old school shocks and springs
lol
Old Apr 20, 2006 | 06:12 PM
1nate7's Avatar
1nate7
I don't know then, because the height adjustment perch for my Tein Basics sits on top of the spring. What kind of coilovers did you get? Tein has installation instructions online. http://www.tein.com/ti/inst/lp26u.pdf
Old Apr 20, 2006 | 06:16 PM
b_nazty's Avatar
b_nazty
i got a set of jic's im not sure what model but i tried looking for the install instructions online but no luck...and jic's website is down
Old Apr 20, 2006 | 06:24 PM
b_nazty's Avatar
b_nazty
the stock rubber peice that it shows on the tien instructions doesnt fit in the hole of the pertch in the jic's like it does in the tiens...i read somewhere that on the jic's its possible that the pertch could sit on the bottom...can anyone verify that?
Old Apr 20, 2006 | 06:25 PM
Vamos_Rafael
i got the same thing
JIC FLTA2's
they only make FLTA2's for 350Z's
it comes with 2 front coilovers,
2 rear shocks + springs + perches
+ adj hex tools
thats it...
its the correct installation
Old Apr 20, 2006 | 06:53 PM
b_nazty's Avatar
b_nazty
so i shouldnt try swithching the setup and just put a thin piece of rubber between the pertch and the car?
Old Apr 20, 2006 | 06:57 PM
Vamos_Rafael
seee how u like the ride
i got used to it...
in the beginning u'll hear rattles and squeaks everywhere
cuz JICs are probably THE harshest coilovers anyone ever released for the Z
Old Apr 20, 2006 | 08:17 PM
b_nazty's Avatar
b_nazty
well i can stand the stiffness but i cant sount the metal to metal sound and it only seems to be coming from the passenger side so i guess ill try to put some rubber in between to see how that helps
Old Apr 21, 2006 | 05:29 AM
Vamos_Rafael
you got on-rails handlings now you gotta compromise xD
Old Apr 21, 2006 | 05:55 PM
b_nazty's Avatar
b_nazty
yeah i know...so i found out today that the perch needs to be connected to the car by drilling holes through them and the car then bolted down..dont know if i want to do that..i guess ill just try to add a thin peice of rubber in between the two and just live with whatever noise is left
Old Apr 22, 2006 | 03:19 PM
b_nazty's Avatar
b_nazty
thanx for all the helpfull info you guys
