Kgmm supersoft springs for Z
Hey guys,
Does anyone has kgmm supersoft springs on 350z?
Based on the website description, it lowers 15mm but someone with G told me it lowers more than an inch. Does it makes difference between G and Z?
Pic would be helpful.
Thanks.
Thanks.
Linky linky to the web site you saw the description on?
If a G35 coupe specific lowering spring is run on a 350Z, the Z will be +.5" to that springs published G35 coupe drop.
You drive a 350Z, correct?
What exact spring from Kg/Mm are you looking at?
Yes, i drive a Z.
Actually i bought a kgmm supersoft springs from G owner. I thought drop would be same but i found this link.
http://bulletproofautomotive.com/cat...ail.php?ID=891
they are the DR21 supersports made for the Z, i had them on my G. they did lower my car a little over an inch, and kept the ride close to stock. what you can do is install one of the rears, thats the easiest to install, just to give you an idea.
hey tig,
I was going to install these to see how much it lowers but i thought i should ask first. i guess im kinda lazy and i already swaped the springs 4 times already.... getting tired of swaping out springs =)
