Eibach Pro-kit on 04 base
Old May 23, 2006 | 08:53 PM
jmwlenz's Avatar
jmwlenz
Default Eibach Pro-kit on 04 base
Hello all -
I just purchased my first Z - an 04 silverstone base. My first mod will be the requisite lowering springs. Here is my question...I want to go w/1.0" lower via eibach pro kits. Will I be able to get the f/r back into alignment w/OEM parts or will I need a camber kit? Anyone w/this setup coud prob answer my Q. Thanks!
Old May 27, 2006 | 06:32 AM
Gsedan35's Avatar
Gsedan35
Originally Posted by jmwlenz
Hello all -
Will the car be within oem alignment specs, No. A while back I did a historic review of Eibach prokit install's limited to owners that talked about alignment after install, that reveiw went back to when this board first started. Of the owner's that ACTUALLY had the car aligned, the car was out of spec and required front and rear correction to get back into spec. Now, for some of those owner's they could not justify the cost of front arms and decided to live with the front being out of spec and they elected to only correct the rear.
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
