Quick Question (Camber)
Old May 28, 2006 | 06:48 AM
HoldThisForMe's Avatar
HoldThisForMe
Default Quick Question (Camber)
I have a rear camber kit I am going to install when I get the car back. My question is can I install the camber kit and have it alligned to -.5 deg with stock 245's and then mount the new 275's i got and the camber still be ok? or should i wait until I have the 275's mounted?
Russ
Old May 28, 2006 | 01:33 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
wait till your new tires are mounted
why would you run such minimal camber? Handling is going to suffer, and you are not going to gain any tire wear vs the factory recommended settings
Old May 28, 2006 | 01:47 PM
HoldThisForMe
factory is killing my tires right now...im about to put DRs on as soon as i get my car back and i want all the tire i can get on the road.
Old May 28, 2006 | 01:48 PM
HoldThisForMe
whoops
HoldThisForMe
whoops X2
Old May 28, 2006 | 01:51 PM
Z1 Performance
Former Sponsor
toe kills the tires, not camber, unless its in the 3+ degree range. Either way you'll be good to go with the SPC kit, as it adjusts rear camber and toe
Old May 28, 2006 | 02:04 PM
HoldThisForMe
thats the kit i got...what range should i go with for best traction?
Old May 28, 2006 | 02:07 PM
Z1 Performance
Former Sponsor
too many variables involved, not the leas of which is the offset of the wheel, etc
If you are at sock rideheight, 1 degree out back would do you well
Old May 28, 2006 | 02:12 PM
HoldThisForMe
yeah everything is still stock...wheel and suspension wise
Rowlett
Misc.
Oct 2, 2015 10:38 AM
