Hotchkis front sway bar - 4 way adjustable?
Old Jun 13, 2006 | 06:56 AM
MoodDude's Avatar
MoodDude
Cool - it is pretty fun to tune the sways and actually feel a difference in how the car handles!
Old Jul 2, 2006 | 07:07 AM
Gsedan35's Avatar
Gsedan35
Originally Posted by GTNPU Z
I believe it's actually an additional "stiffer" setting. The additional hole should be located towards the inner most part of the bar. See below...
Specs:
Front 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs)
4 Position Adjustable
Rear 15/16"(24mm) Tubular(bar weight 5.5lbs)
3 Position Adjustable
Bar Rates:
350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
06 G35 Front
Hole 1 = 1525 lbs/in (5% Softer than stock)
Hole 2 = 1845 lbs/in (15% Stiffer than stock)
Hole 3 = 2270 lbs/in (42% Stiffer than stock)
Hole 4 = 2855 lbs/in (78% Stiffer than stock)
Rear:
Hole 1 = 520 lbs/in (80% Stiffer than stock)
Hole 2 = 655 lbs/in (125% Stiffer than stock)
Hole 3 = 840 lbs/in (185% Stiffer than stock)
This was their old setup:
Front 1 3/8" (35MM) Hollow (Bar Weight 13.5lbs)
- 3 Position Adjustable
- Rate Increase over stock: +9%,+32%,+63%
Rear 15/16"(24mm) Hollow (bar weight 5.5lbs)
- Rate Increase over stock: +54%,+92%,+146%
All G35 and 350Z oem sway bar specs follow a more complicated path then Hotchkis's limited sampling, thus they aren't telling the whole story.
I can specifically fill in the gaps.
Group A
03-04 350Z all trim levels (car's without the revised suspension ONLY)
03-06 G35 coupe (all USDM production with oem 17 and 18" wheels)
03-04 G35 sedan (sport and non sport suspension's
All group A car's have the following oem sway bar specs
34mm front 21mm rear
hollow wall construction 5mm in thickness (courtesy of tomsn16)
Torsional rigidity Front: 1130lbs Rear:385 (courtesy BJ EVO350)
Group B
04.5-06 350Z all trim levels (car's with the revised suspension)
05-06 G35 coupe (all USDM production with oem 19" wheels)
04-06 G35 sedan (sport and non sport suspensions)
hollow wall construction 7mm front (courtesty tomsn16) 5mm rear
net change in front bar strength from 2mm increase in wall thickness
+17% (courtesty of tomsn16)
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Apr 28, 2017 09:00 PM
