Ebc Problem??
Old Jun 28, 2006 | 01:37 PM
InItIaLD's Avatar
InItIaLD
Default Ebc Problem??
i have installed these pads on my 350z, and they squeal and whistle a bit with brake pedal released.. as soon as i tap the brake gently they stop... and start whistling again a few seconds later, i suspected the Shim to have come lose from the back of the pad, and to my surprise they didnt lift but slid over to one end of the pad.. i was wondering has anyone had this problem?.. are we not supposed to put the OEM shims on those pads? one of the boxes that i have for the rear pads (cant find front pad box.. front is where i have the problem) says "integrated Shim" on it.. but uhh.. i didnt really see one on it.. just wondering if anyone else has had this problem
i'd appreciate any input on this. thanks guys.. i've always gotten kick *** advice/tips here, thought id try again in hopes for the same
Old Jun 28, 2006 | 02:22 PM
DavesZ#3's Avatar
DavesZ#3
If your pads didn't come with shims, then you need to remove the stock ones and use them. At least that's what I did with the Endless pads that I bought.
Old Jun 29, 2006 | 06:09 AM
Tekwon-V's Avatar
Tekwon-V
i didnt think it was necessary to re-use(assuming they are in decent condition) shims but i did it anyway with my HP+ setup.
Uriyo_
Sep 8, 2021 08:46 AM
_bit
Oct 2, 2015 07:49 AM
