camber?
My car is not lowered but I want my camber at 0. This is to get as much tire to the ground as possible. I am not worried about super handling since I only drag race the car. Can I adjust the camber to 0 with the stock setup or do I need to purchase an aftermarket camber adjuster? Also which ones are cheap but well made? Thanks
Originally Posted by wldkatz03
depends on how low you went...less than an inch all around will allow you to get back into factory specs
Try reading the whole question before answering. - 0 - camber is not within specs to start with.
You should look into the spc camber kit with toe bolts. You should be able to get to - 0 - camber with that and NOT LOWERED.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
