How good is factory brembo???
Old Jul 22, 2006 | 08:48 PM
vince1611's Avatar
vince1611
Old Jul 22, 2006 | 10:22 PM
FrickU's Avatar
FrickU
The brembos will last you 3 laps on a track with hard braking before they start overheating and fading...If you plan to track your car, then save up and get some AP Racing brakes, or some Rotoras.
Old Jul 22, 2006 | 11:50 PM
Mazinger Z's Avatar
Mazinger Z
Originally Posted by vince1611
??? Am I missing something here? Brakes work better when cool (that's why rotors are slotted and cross drilled) if that's what you have mixed up.
I think he's talking about "operating temperature"...some bbk needs to be warmed up before they start operating at the most efficient level...
Old Jul 23, 2006 | 12:15 PM
sentry65's Avatar
sentry65
the burninator
have you faded the brembos yourself or seen someone do it first hand? or you just repeating some word of mouth you heard somewhere?
were they using stock brake fluid?
Old Jul 23, 2006 | 01:32 PM
Mike Wazowski's Avatar
Mike Wazowski
He actually works for VRT and has tracked the Brembo's vs. AP Racing 6 pot system.
Old Jul 23, 2006 | 02:48 PM
roast's Avatar
roast
No two tracks are created equally. Fade after 3 laps on one track could be 10 laps on another. I think it goes without saying that some tracks are much more demanding on brakes than others. I find it silly to say "fade will occur after X amount of laps", then again, what do I know.
Old Jul 23, 2006 | 03:54 PM
Lerxst's Avatar
Lerxst
3 laps... 10 laps... all I know is that my Brembo's with Hawk HPS pads worked awesome after 3 5-lap sesssions. EVERYONE else was having bad brake fade and mine were holding up just fine.
Different brake pads like different temperatures. Some hardly work until heated up (e.g. racing) because normal operating temps are so high. For street use, you won't see that kind of demand, so the pad formula is designed to operate at cooler temps.
Old Jul 23, 2006 | 07:43 PM
ht4's Avatar
ht4
The BBK doesn't matter. This is determined 100% by pad compound.
Racing compounds have better bite at higher temps, but tend to be loud, wear through rotors and have poor braking at low temps.
Street compounds will give you better rotor wear, better low-temp bite and less noise... but fail at high temps.
Many of the performance pads people on this forum use (such as Hawk HPS) are a good compromise between these two extremes.
Old Jul 24, 2006 | 11:15 AM
MAXecutive's Avatar
MAXecutive
Thanks, thats the answer I was looking for.
Old Jul 24, 2006 | 12:37 PM
seeulater's Avatar
seeulater
I just finished upgrading my brakes and really love what the results are. I put on EBC slotted and milled rotors with EBC red stuff pads along with stainless steel lines and high temp fluid. I am pretty hard on my car and demand performace from it. After these brakes were installed it was amazing how much more fade resistant they really were. NOt only are they more fade resistant but they have great bite too. I can do repeted stops from 100 to zero and have no problems at all. I have not gotton it on a track yet but I have confidence that this set up should hold up.
Zbuzz
May 19, 2011 06:53 AM
Vivid Racing
Apr 12, 2009 05:55 PM
daytona350z
Jun 19, 2003 03:04 PM
