Track Brembos on Performance Model?
Old Sep 7, 2006 | 07:07 PM
dixiecrawler's Avatar
dixiecrawler
Default Track Brembos on Performance Model?
I'm sure this has been asked, but I couldn't find it when I searched, so here goes. I am wondering if it is a direct fit to put track Brembo rotors and calipers on a non-Brembo model? Thanks in advance for the help.
Old Sep 7, 2006 | 07:09 PM
zand02max's Avatar
zand02max
Will not work on the Performance 18" Rims!
Old Sep 8, 2006 | 05:04 AM
davidf's Avatar
davidf
Time for some 19's.
Old Sep 8, 2006 | 05:48 AM
gringott's Avatar
gringott
Originally Posted by zand02max
Will not work on the Performace 18" Rims!
I didn't know that! Good thing my ebay bids failed. I use those for my winter tires! Thanks for the heads up.
Old Sep 8, 2006 | 07:49 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Stock Performance 18 inch wheels WILL clear facotry BREMBO's.
Old Sep 8, 2006 | 07:54 AM
spacemn_spiff's Avatar
spacemn_spiff
+1. Stock 17" will also clear Brembos, have had them for months now without any issues.
Old Sep 8, 2006 | 06:50 PM
dixiecrawler
I have 20's. So you are saying they will bolt right up as long as I have wheel clearance? I hope so. My brakes are WAY too small for my wheel as far as looks go.
Old Sep 8, 2006 | 06:52 PM
zand02max's Avatar
zand02max
Really, I thought back in 03 when they came out, the 18" wheel would not fit over the Brembo's. I stand corrected, my bad!
Old Sep 11, 2006 | 02:44 PM
Andy@Performance
Performance Nissan
They SHOULD clear, I am not sure of the specs on your wheels but if I had to guess it should. If you are talking about buying the factory BREMBO's brand new, I would look for different alternatives as you can find much better braking systems for the same price as the factory BREMBOS. Check out the link below.
https://www.mynismo.com/categories/?id=2313
Andy@Performance
Performance Nissan
No worries, we all learn something new everyday.
Old Sep 11, 2006 | 05:31 PM
dixiecrawler
I've just been curious. I was thinking that I may come across someone wanting to replace their factory Brembos with something else. Just a thought, just wanted to make sure there wasn't something different in the mount points or anything. Thanks for the info.
Old Sep 11, 2006 | 07:49 PM
GaryM05's Avatar
GaryM05
The only difference is that the rear caliper mounting bolts are a different thread pitch on the Brembos than the non-Brembos. So if you buy someone's used Brembos (check the classifieds and Ebay, as these are often available), make sure you get the rear caliper mounting bolts. Otherwise, you'll be in for a trip to the hardware store or the Nissan parts counter.
Old Sep 13, 2006 | 03:40 AM
lve2xlr8's Avatar
lve2xlr8
I found Brembos at a junkyard last weekend on a g35 coupe and put them on... They're sexy So are my G35 19's
Old Sep 13, 2006 | 05:26 AM
rromero's Avatar
rromero
running brembo's on my Touring. will fit 17" and 18" stocks
Old Sep 13, 2006 | 04:30 PM
dixiecrawler
Thanks for all the info guys. You have been alot of help. BTW, lve2xlr8, how much did you have to pay for those brakes at a junkyard?
Old Sep 13, 2006 | 09:13 PM
jinsei888's Avatar
jinsei888
Performance 18" stock wheels WILL clear the stock Brembos. Japan OEM offered only the standard 18's (non-Rays wheels) for the brembo brake offering. Fit's and clears just fine with stock offset and what not.
Old Sep 14, 2006 | 08:16 AM
mberthia's Avatar
mberthia
How about the fronts? The mounting bolt can be reused switching from the non-Brembo to the Brembos ?
Old Sep 14, 2006 | 06:29 PM
GaryM05's Avatar
GaryM05
Yes, as far as I know the front bolt is the same (although I've never actually seen it).
Old Sep 30, 2006 | 11:09 AM
buffmanjeff's Avatar
buffmanjeff
Question for you guys....will G35 brembos be a direct swat with my Z's non brembos? Been looking around to find out.
Old Mar 1, 2007 | 01:34 PM
lve2xlr8's Avatar
lve2xlr8
Yes they will, make sure u get all the parts, ie. the brake lines, and brake line holders as well as rotors and etc.. Also, I paid $100 for my brembo setup at the junkyard
